Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 29th May 2012, 09:51 PM   #361
ED
Old 30th May 2012, 12:09 AM   #362
opc is offline opc  Canada
opc's Avatar
Hi Ed,
Parts arrived today. Thanks for the quick turnaround and excellent packing!
Owen
Old 31st May 2012, 03:56 AM   #363
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
I am going to purchase a piece of 3/16" X 1/2" 6061 aluminum and attempt to make some heat spreaders to use along with flat-back heat sinks.
I'm going to try to use a flat bed sander to remove ~0.006-7" from the bar stock to match the thickness of the buffers.
If that is successful I'll make a jig to cut a rebate (lap) onto one edge of the prepared stock.
If all that is OK I'll drill and tap some holes. I'll have enough stock to make more. I need a proof of concept first. I'll keep you informed.
What are your thoughts for positioning of thermal insulators?
What are the particular surfaces which MUST be electrically isolated?
How will you dress the solder connection of the 49600 tab to the PCB?...I'm guessing that I don't want any goobers there.
Old 31st May 2012, 06:46 AM   #364
Ed,
I know we've all had a few discussions about heatsinks already, now spread over both threads and many months, but after working it through over email, qusp and I came to the conclusion that heatspreaders underneath the pcb and attached to an enclosure would probably be the ultimate solution. I think this is a variation on one of your earlier suggestions.
I've attached a model that I drew when thinking up ideas for a custom floor that was going to be made by hypertune but is on hold till we find out exactly what's going on there. I believe a similar result could be had with aluminium bars, that is essentially the backup plan that qusp and I have.
I have dimensions for the attached diagram, though the mounting holes are more diagramatic in their location everything else should fit and has space allowance for the components mounted to underside of the pcb.
Thought I'd share it and see if it helps with any alternative ideas you come up with. It's been frustrating experience so far and qusp, opc and I have all invested significant effort in trying organise to get hypertune over the line with this and we've had no joy so far.
If you go through with any order of 6061, let qusp and I know as it seems likely we'll place an order with onlinemetals in the near future so I think we may be interested in adding to your order if that is possible or convenient.
Chris
File Type: jpg lpuhp enclosure floor - almost iso.jpg (122.5 KB, 67 views)
Old 31st May 2012, 02:30 PM   #365
...truth seeker...
Chris, Your approach kicks my analysis back in gear with my first cup of coffee.
Over in the other thread, exa065 provided a view of his solution in post #444:
I share this to aid in our discussion. Help me work through my speculation to assure us all that I understand.
My thoughts in my last post have the sink positioned just as exa065 does.
The bars I posted on above would obscure from view the ends of the buffers in exa065's photo.
I have obtained this enclosure from Fair Radio that I described over there in post #152:
My plan was to vent the enclosure and rely upon convection for cooling. Your approach would allow me to capitalize upon the ribbed section of my enclosure and dispense with internal buffer sinks.
Your below board schema have 4 areas of contact: 1 under each row of buffers, 1 under the op-amps and 1 under the transformer. I like your approach.
I was going to order aluminum stock this morning. That is now on hold for further discussion.
Do I understand?
Old 31st May 2012, 02:42 PM   #366
Do I understand?
You've got it perfectly Ed!
The idea was driven to try to avoid ventilation being necessary for the buffer heatsink and to minimise enclosure size/height (enclosure becomes the heatsink like you've said) since we're still doggedly marching down the path of the mini-block!
Without having it machined from a single block I am not sure how to secure the bar for the opamps in place other than to rely on friction. Any ideas?
You're having your first coffee and my head is overdue for a meeting with my pillow!
Old 31st May 2012, 03:32 PM   #367
...truth seeker...
Sweet dreams!
Note the data sheet gives a range of thicknesses. Direct measure of one of the LME49990 is 0.063". I think this is suitably close to 1/16" to allow heat sink compound to fill the gaps.
Select stock where the difference in thickness is equal to the thickness of the op-amps.
For registration I would extend the op-amp spreader to engage to outermost corner holes of the board.
Relief would have to be provided so the op-amp spreader and the buffer spreaders don't foul one another.
This becomes a simpler install than the fiddling I was going to do.
What stock do you want? How can I help? Are we having fun yet?
https://www.speedymetals.com/c-8351-6061.aspx
That is a link I had chosen to secure the goods.
Old 31st May 2012, 05:40 PM   #368
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
indeed if building your own, bottom is the way to go, I found its hotter under the board too as the heat from the buffers and the VAS is under there. that was our thinking, heat would be sunk to an external surface so ventilation in the case was not a factor.
it also means the amp is more easily tested under full load, with full access to the top of the board for probing, more room in the enclosure for neat layout, wire routing or other components and as you say a much easier install, just screw it down, done.
Old 1st June 2012, 04:58 AM   #369
...truth seeker...
When can you let me know if you want aluminum stock?
I'm ready to order.
Old 1st June 2012, 05:29 AM   #370
My guess at the moment is inside next 12 - 24hrs we'd let you know either way. We've tried again today to get in touch with Mark, I haven't heard how qusp has gone with that.
The Wire - Low Power Ultra High Perfromance (LPUHP) 16W Power Amplifier opc Solid State 550 7th May 2013 02:05 PM
O2 amp parts GB, EU Jokener Group Buys 791 25th June 2012 04:27 PM
O2 amp Australian parts GB BlueFusion Group Buys 1057 12th May 2012 02:39 PM
Furutech Power Parts GB promitheus Group Buys 5 22nd August 2006 07:37 PM
Copyright ©1999-2013 diyAudio
