| Group Buys Members group buys |
This is an offer from Toroidy for F5X transformers. These are the characteristics of them:
600VA audio quality transformer Primary: 230V, 50Hz Secondaries: 2x16V, Bifilar wound Shields: - Electrostatic shield between primaries and secondaries with earthing connections - Electromagnetic shield on the perimeter outside the secondary winding Isolation: Temperature class B , 130⁰C per IEC 085 Ta 60⁰C VDE0570 EN/IEC 61558 IP 00 Test voltage: Primary - secondary: 5000V Secondary -Secondary: 500V Dimensions: Outer diameter ~145mm Height ~57mm Electrical connections: Free-length enamel wire 200mm long Fixation: open core not potted, centre bolt, disk & rubber gasket. Therefore, the transformers accomplish all the specifications made by Patrick( EUVL). The price for each piece is 69,40 EUR if we buy 10 to 20 pieces, and 65,80 EUR if we go for 20 to 30 pieces (prices with 23% VAT included). The shipping is a little expensive, because a package up to 30kg to Spain is 28,00 EUR (The app. weight for a transformer is 5Kg) .From an earlier post in the forum it's 15,00 EUR to Germany. Perhaps we can find a cheaper shipping method. If you are interested, please, put your name and quantity below: - EUVL 2 transformers - Mravinsky 2 transformers Antonio |
#2 |
- EUVL 2 transformers - Mravinsky 2 transformers - NicMac 2 transformers |
#3 |
Antonio,
Thank you for taking the initative to organise this. Yes, I'm in for a pair if the shipment can be resolved. I am sure we can find a solution, somehow. Patrick
xen-audio.com |
#4 |
- EUVL 2 transformers - Mravinsky 2 transformers - NicMac 2 transformers - Ramallo 2 transformers - Oneoclock 2 transformers
Happiness is a warm soldering iron
#5 |
Antonio,
I talked to heinz1. I think we'll have a solution for shipment. Please get in touch with him direct. Thanks, Patrick
xen-audio.com |
#6 |
- EUVL 2 transformers - Mravinsky 2 transformers - NicMac 2 transformers - Ramallo 2 transformers - Oneoclock 2 transformers - pmchoong 2 transformers |
#7 |
Hi Antonio,
What will be the shipping fees to Malaysia and what about the transformer for the speaker protection? Thanks. |
#8 |
- EUVL 2 transformers - Mravinsky 2 transformers - NicMac 2 transformers - Ramallo 2 transformers - Oneoclock 2 transformers - pmchoong 2 transformers - potepuh 2 transformers |
#9 |
- EUVL 2 transformers - Mravinsky 2 transformers - NicMac 2 transformers - Ramallo 2 transformers - Oneoclock 2 transformers - pmchoong 2 transformers - potepuh 2 transformers - JBdV 4 transformers Last edited by JBdV; 11th January 2012 at 11:56 AM. Reason: added one space ;-) |
#10 |
Choong,
If sent from Germany to Malaysia, shipment would be 55 Euros for 10kg (as far as I understand 5kg per Tx), or 80 Euros for 20 kg if you go over the 10kg limit. On top of that you still have to pay shipment from Poland to Germany. There is no direct shipment possible from Poland to Malaysia, as I understand. So maybe it is better for you to go with a US GB (if there is one in the pipe). Patrick
xen-audio.com |
| F5X -- the EUVL Approach | EUVL | Pass Labs | 732 | 6th May 2012 07:37 PM |
| GB 2SK3497/2SJ618 for EUVL F5X or other projects | pchw | Group Buys | 266 | 8th April 2012 06:05 PM |
| F5X Transformers | mravinsky | Group Buys | 1 | 10th January 2012 04:40 PM |
| F5X from diyAudio Boards P-F5c-2V20e | JBL4435 | Pass Labs | 54 | 16th November 2011 08:26 PM |
| F5X using Peter Daniel boards? | speakrsrfun | Pass Labs | 2 | 16th November 2011 06:15 AM |
| Page generated in 0.51720 seconds (-55.96% PHP - 155.96% MySQL) with 11 queries |
