Group Buys Members group buys
Official O2 Headphone Amp Front Panel Group Buy
Old 14th December 2011, 09:00 AM   #501
greenalien is offline greenalien
Just to point out that the cases should come supplied with with 2 sets of fasteners - one set of 8 x Phillips-head and one set of 8 x Torx head. They are self-tappers - I had no problem using the Torx-head fasteners, although a spot of lubrication on the threads is a good idea. I suspect that using the Philips-head fasteners to cut the threads may result in a chewed-up screw head or two as a certain amount of effort is needed when cutting the threads for the first time. Using the Torx screws, with the correct-sized bit, nothing slipped at all, and they look good.
Old 14th December 2011, 01:02 PM   #502
jtktam is offline jtktam  Canada
By using the correct sized + tip you should not have any issues with the screws.
I would say don't try to go 90mph on the screws, slowly and surly.. if it doesn't want to turn any more, back out a bit and turn again..
-joe
Old 14th December 2011, 08:13 PM   #503
RDGinSA is offline RDGinSA  United States
Hi jkt:
I had a good chuckle over your comment about driving in the panel screws. I confess to getting a bit "surly" myself, when trying to drive Philips head screws and having the driver bit slip and strip the screw head -- I much prefer Robertson or Torx head screws. On my amp, I used the Torx head screws to fasten the back panel. I agree with greenalien's comment: the Torx heads went in easily and securely and I think they look fine.
--RDG
Old 14th December 2011, 09:03 PM   #504
HaroldHill is offline HaroldHill  Canada
Just curious: How common are Robertson screws in the U.S.? I was told they were only used in Canada.
Originally Posted by RDGinSA View Post
Hi jkt:
--RDG
Old 14th December 2011, 09:18 PM   #505
MrSlim is offline MrSlim  Canada
It's like other Canadian exports that are slowly being infiltrated into American society.. Can you say Canadian Comedians..
Seriously.. A few years back when TVs were still being built in the US (Curtis Mathis), I discovered that they were using Robertson head screws as "security" screws on the back of their sets since they weren't readily available there..
Old 14th December 2011, 09:26 PM   #506
Although Robertson head (square drive) fasteners are much less common in the US than in Canada, they do turn up occasionally here and are available in specialty shops. I became acquainted with Robertson head screws (and other Canadian delights) many years ago when I went to graduate school in Toronto. That experience caused me to equip my toolbox with a good size selection of Robertson drivers. Generally, I prefer Robertson head to Philips head fasteners and use them when I can get them. That being said, Torx is probably the best of all - that design provides a really positive grip on the screw. The downside, of course, is having to buy yet another set of specialty tools.
Old 14th December 2011, 10:29 PM   #507
flynhawaiian is offline flynhawaiian  United States
I understand about the self taping screws, but having worked in a machine shop I can tell you that isn't the best way to thread. As said, I would use a 6-32 tap, but you guys can choose your own method. Just my recommendation.
None the less all packages have been shipped out as of today!
Old 14th December 2011, 10:41 PM   #508
sebash is offline sebash  United States
Thanks for your hard work, now we can all eagerly await the packages.
Old 14th December 2011, 10:45 PM   #509
Brilliant - thanks a lot for all your effort.
what's that in metric.... - yes, even the home of the Imperial measurement system doesn't use it any more!
Old 14th December 2011, 11:09 PM   #510
Metric = 3.5 x .06. 3.5mm diameter - 0.06 thread pitch. I would rather use metric any day of the week. Slugs aren't my favorite flavor of measurement :/
Official O2 Headphone Amp Front Panel Group BuyHide this!Advertise here!
The Objective2 (O2) Headphone Amp DIY Project RocketScientist Headphone Systems 5244 12th June 2018 05:08 PM
O2 Front Panel GB Interest flynhawaiian Group Buys 254 6th October 2011 04:28 AM
Official Group Buy for Autotech Waveguides. Scaper Group Buys 10 24th May 2011 10:50 PM
