Group Buys Members group buys
Discrete Low Jitter Clock GB
Old 8th October 2012, 08:55 AM   #151
ymwong is offline ymwong  United States
HI Anton,
I would like 2 DC kits plus 2 bare PCBs.
Thanks,
ym
Old 8th October 2012, 09:43 AM   #152
amc184 is offline amc184  New Zealand
amc184's Avatar
Thanks for the orders so far.
There seems to be a little confusion over AC and DC kits and the bare PCB. The AC and DC versions of this clock use the same PCB. The two kits have a slightly different bill of materials, and when you build the DC version you can cut part of the PCB off to make the clock more compact.
When ordering you don't need to specify whether you want a PCB for an AC or DC version, they're the same thing.
@WALTER BURKHARD: Do you mean a DC powered kit or an AC powered kit without the transformer?
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 8th October 2012, 04:49 PM   #153
syklab is offline syklab  United States
Hi Anton,
Can the clock work with 50Mhz crystal? Or Can I use it to replace the 50Mhz crystal on my dac?
Old 11th October 2012, 01:32 AM   #154
amc184's Avatar
A few people have asked about payments etc. I plan to do this the same way as I did for the first round.
- At the end of this month I will close this round and take payments.
- Once I've received payment I will ship orders to those who ordered bare PCBs only and order the parts for the kits.
- Once the parts for the kits have arrived I will ship the orders that include kits.
@skylab: I'm not sure it will work that high, I've only tested it to 33.8688MHz, the highest common CDP clock frequency. What device are you referring to that has a 50MHz clock?
Old 11th October 2012, 03:17 AM   #155
I built the ES9023 DAC (Subbu DAC) and it uses a 50mhz crystal for MCLK and that's why I ask if the clock can run at that speed and can replace that crystal. The recommended speed for running in asynchronous mode must be >192*fs which translates to min 36.864mhz and 49.152 mhz for 256fs.
Old 12th October 2012, 08:46 AM   #156
ThuyTN is offline ThuyTN
Send a message via Yahoo to ThuyTN
2x bare pcb please.
Old 14th October 2012, 01:47 PM   #157
jameshillj is offline jameshillj  Australia
Please add me for a dc kit @ 11.28...MHz - thanks.
Old 16th October 2012, 07:03 AM   #158
tagheuer is offline tagheuer  Canada
Originally Posted by tagheuer View Post
Hi there,
In this second round GB, I would like to order:
2 x Kit for 7 - 20VDC powered version
2 x Bare PCB
Hi Anton,
I would like to revise my order to the following:
2 x Kit for 110 - 120VAC
2 x Bare PCB
2 x 110 -120 VAC power transformer only
Old 16th October 2012, 07:49 AM   #159
amc184's Avatar
@syklab: Okay, that's an appropriate application. I haven't tested it at frequencies that high, so I can't surely say it will work. However, I've tested it up to 33.8688MHz, 50MHz is not a huge amount higher, so it will probably be okay.
@tagheuer: Unfortunately I'm not supplying a mains AC powered clock suitable for North American voltage. I used a transformer with a single 230VAC primary winding. If you're really keen for a 110-120VAC version, PM me and we may be able to work something out.
Old 16th October 2012, 01:00 PM   #160
Ok, I'll send you a PM.
At the mean time, please revert back to my original order:
2 x Bare PCB
Thanks.
Discrete Low Jitter Clock GBHide this!Advertise here!
FS: Low Jitter Clock PCBs amc184 Swap Meet 7 1st September 2015 06:09 PM
opamp / low jitter clock for maranatz sweepy DIY HiFi Supply 1 5th April 2011 01:48 AM
Is this cristal clock schematic would have a low jitter ? gaetan8888 Digital Line Level 8 20th May 2010 03:13 PM
low jitter clock help needed atcgreg Digital Line Level 10 9th June 2009 07:58 AM
Another clock idea for low jitter Bernhard Digital Source 7 29th October 2004 05:05 PM
