Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 24th September 2011, 07:13 AM   #21
Originally Posted by hags View Post
I don't see C46-C53 marked on the board. I see where they go but they are not marked as to values.
Maybe I am overlooking something?
Yes its not marked on the board. I have provided you the component layout you will be able to place all components easily using that. It is clearly marked on the component layout where you can place C46-c53, check it out.
Old 3rd October 2011, 06:33 AM   #22
noSmoking's Avatar
Hi everyone!
I just built this board had to stop parts I had ditin' fit lol,But the build was easy no hangups at all, I got 2 boards so I have another to build and play/experiment with,I'll post when it's done and played some,and see how it sounds not heard a 8741 yet!
Happy listening!
Old 12th October 2011, 11:42 PM   #23
noSmoking's Avatar
I found some shorts on the clk ps circuit and around 2 square pads had to razor them clean,they had green mask over them but were in plain site,I built the PS section first and checked voltages as I populated the board,It works good now sound is better than my 8740 so now I will tweak it a bit,The digital filters do make a difference in sound but I don't think I would need the switches because I have them set and haven't changed them since so jumpers would do fine here.I will play it continous for a couple of weeks and see how it sounds then,Anyone made any mods so far?
Happy Listening
Old 11th January 2012, 08:28 PM   #24
jazzm is offline jazzm  Canada
Can you post please some detailed specs as to the bit-rate/freq for up-sampling, input digital signal requirements, additional modules specs and details? What are the specs on the analog output? Is it balanced? I only see a single output connector, can you please clarify?
Thanks,
Tom.
Old 19th January 2012, 09:56 AM   #25
Is this GB closed now?
Old 19th January 2012, 09:58 AM   #26
oops - previous page: I will sort out details later...
Old 19th January 2012, 12:12 PM   #27
Yes, the GB on this is closed now. You can check out new version of this DAC.
High Performance WM8741 Super Mini DAC PCB Group buy heartwinter Group Buys 18 30th August 2011 05:45 PM
Group Buy: QRV09 Ultra High Performance Headphone Amplifier peranders Group Buys 74 30th May 2011 12:12 AM
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
Page generated in 0.09510 seconds (72.61% PHP - 27.39% MySQL) with 10 queries
