Okay, that's not what I wanted to read.Hmm... It is a bit dodgy. When the next batch of boards arrive I'll be in touch and we can sort something out.
So, basically, you're calling this "dodgy" in a "the boards were probably lost somewhere out there" way, right? Well... that's a pity. And bad luck, I guess.
Nevertheless, thanks so much for your support, Olli!
Should I sing up to the second GB, just to make sure I'm in, or could you just send me a quick note?
How to lower the gain?
the stock is 2.5 / 6.5
so i removed the 6.5 gain resistors from r19/r23, then moved the 2.5 gain resistors from r17/r21 to r19/r23
no resistor = 1.0 gain
-joe
It is a minor point, but if you are settled on 1x as one of your gain settings, I'd put a 10k~50k resistor in there instead of leaving it open. A little current shunt to ground will improve noise immunity a touch, likely inaudible in 99% of situations. You certainly wouldn't be able to detect the small increase above unity gain.
<looks over at his pile of resistors>
I will try that.. thanks
-joe
<evil grin>
<evil grin>
Is that all?
I have 50 on the way
I haven't gotten anything (USA) yet. Is this normal? I don't mind waiting, I just want to make sure I get the two boards I paid for. Thanks
Doesn't sound good... I am completely out of stock of boards so it might be necessary to issue you a refund and offer my apologies.
If this is the path you want to go then drop me an email and I'll sort that out for you.
Seriously? How did that even happen? I've been in on this group buy almost from the beginning.
It sounds like your boards were lost in the post.
- Group Buys
- O2 Headphone Amplifier GB
