Group Buys Members group buys
group buy for DX Blame MKIII Hx PCBs
Old 30th July 2011, 11:26 AM   #121
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Yes Buzz... this makes a lot of sense.
This amplifier can work from 15 plus and minus to 64V plus and minus....so...you may have lower power if you need...also you do not need to use all these output transistors while using lower supply voltage, that will result in lower power output because the lower supply voltage.
Visit MKIII thread...there you have this posted in questions and answers i have made to myself in order to help buiders about this kind of doubts they may have:
http://www.diyaudio.com/forums/solid...leased-31.html
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 30th July 2011, 11:33 AM   #122
buzzforb is offline buzzforb  United States
buzzforb's Avatar
If this is true, I still want my boards. I assume there is no sound degredation with less ouput transistors?
Old 30th July 2011, 11:48 AM   #123
Default I have tested using 21 plus 21 volts supplies and sound was perfect
We have to tweak bias circuit resistors as explained in previous recent videos.
I have also tested using 35 volts supplies (Home Edition)
Also tested using standard supply voltage.
Just for fun i have checked with two 9 volts batteries and worked fine too.
I do think from 35 to 64 volts result was better....well, lower power in December....if you want optimized units for low power, then is better to cancel your order and wait December.
I will not help modifications for this model to avoid to become crazy...as i may have too much work thinking about several different amplifiers at same time.
Sorry, i am already developing, and testing, 5 different amplifiers...this is already too much....amplifier is a system....to each power and supply voltage we have to adjust several things to optimize performance...each one must be understood as a different amplifier.
Reduction in power and supply voltage will allow amplifiers to operate...but not optimized having the best possible performance....want the best possible performance to lower power units?...then wait December.
This amplifier is a monster!.... a killer!..... be carefull if you have sensitive low power speakers...they will melt...this is guaranteed
regards,
Carlos
Old 30th July 2011, 11:58 AM   #124
buzzforb's Avatar
I will wait then. Pleases remove me from the list. As I said before, I will honor my agreement if Byron is left with boards.
Old 30th July 2011, 08:26 PM   #125
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
The european groupsbuy will normaly ends tomorrow but I've decided to let it run a week longer.The reason is 16 boards left over so people if you want boards first talk to Byron and he will contact me.
Old 31st July 2011, 04:48 AM   #126
Default I have opened the Dx Blame MKIII-Hx builder's thread
It was opened for you to read adjustment instructions, modifications, updates, upgrades and tips and tricks.
Also for you to show your work, your pictures about, your construction, your parts, your chassis, yourself and whatever you want to ask, to say and to post.
Here you have the link:
Dx Blame MKIII-Hx - Builder's thread
regards,
Carlos
Old 31st July 2011, 03:23 PM   #127
Default Fixed a mistake i have made in the schematic
attached.
regards,
Carlos
Old 31st July 2011, 05:14 PM   #128
a.wayne is offline a.wayne  United States
Sin Bin
regards,
Carlos
This is good , plan on using 28-32 volt psu .........
Old 31st July 2011, 07:00 PM   #129
tome is offline tome  Macedonia
In this case I'll take my 2 boards from Meanman.....I'm in Europe
I need e-mail from Bayron or Meanman pls.
Old 31st July 2011, 07:10 PM   #130
Ok tome,
You have 2 boards update will be done next week also sent you a mail
group buy for DX Blame MKIII Hx PCBsHide this!Advertise here!
Dx Blame MKIII Supercharged will soon be released destroyer X Solid State 346 22nd April 2014 04:01 PM
DX Blame Group Buy Rudi_Ratlos Group Buys 412 19th August 2012 05:00 PM
Group By: DX Blame MKIII Hx boards ByronInPortland Group Buys 9 19th July 2011 08:21 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Copyright ©1999-2017 diyAudio
