PCB for cascoded IXYS CCS (tube) - Page 30 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 3rd November 2012, 11:39 AM   #291
10y is offline 10y  Italy
Originally Posted by Gluca View Post
The dropping R before the CCS can be anything > 1k
Hi Luca,
How set the desired voltage and current at output of ccs?
Ciao,
Anto
Old 3rd November 2012, 12:51 PM   #292
Gluca is offline Gluca  Italy
Gluca's Avatar
Current is set via the trimmer P100 (and P200), you cannot set voltage in CCS mode that will depend upon the tube bias. You can set voltage in gyrator mode by trimmer P101* (and P201*) ... se schematics at post 153.
Old 3rd November 2012, 01:55 PM   #293
Thank you Luca.
So if I set fixed negative grid voltage and set a target current by ccs trimmer I will have the working-point voltage on plate.
Le t me now If I am right.
Have you used the gyrator mode ? what difference have you found with ccs?
Anto
Old 3rd November 2012, 11:12 PM   #294
Gluca's Avatar
Yes, you are correct. Actually I trim the CCS current to hit the desired plate voltage as my amps are DC coupled (and fixed bias at cathode).
So far, I never used the PCB as gyrator
Old 5th November 2012, 05:35 PM   #295
Thank you Gluca!
Resistor on ccs pcb must be 1 watt or more?
Anto
Old 5th November 2012, 06:13 PM   #296
Gluca's Avatar
That depends ... W=R*I*I
Old 6th November 2012, 04:54 PM   #297
...and in yours what power value you have selected ?
Gluca I have another question : how much voltage I will add at B+ input ccs for an adequate headroom? If I have a plate voltage of 650 V 100 V added would be right?
Ciao,
Anto
Old 7th November 2012, 05:05 PM   #298
Gluca's Avatar
B+ on the plate of the tube plus half the swing you need at the grid of following stage plus headroom
example
650V at the plate
200Vpp to swing the grid of final tube at full power
30V headroom
required voltage at CCS is 650+200/2+30=780V
sum the voltage drop across the resistor to that number
Old 8th November 2012, 05:31 AM   #299
example
650V at the plate
30V headroom
Old 8th November 2012, 05:32 AM   #300
forgot to write, ops....
thank you Gluca.
Anto
cascoded bjt ccs - design check please aardvarkash10 Tubes / Valves 12 17th December 2010 09:07 PM
LTP CCS IXYS with 10m45s opinions aroS3 Tubes / Valves 7 30th May 2009 02:47 AM
IXYS 10M45 CCS IC question zobsky Tubes / Valves 19 26th July 2008 08:15 PM
6SN7 Cascoded CCS korneluk Tubes / Valves 3 25th November 2007 10:02 AM
IXYS 10M45 chip CCS Alastair E Tubes / Valves 3 31st December 2006 12:45 PM
Copyright 1999-2017 diyAudio
