Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 29th August 2011, 07:27 AM   #271
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Originally Posted by Dagwood View Post
Hi Ale
Great breadboard, did you diy it?
Yes. A small metal box with multiple valve sockets and 2mm connectors. It's dead easy to test various configuration in seconds without soldering. I also have an array of LEDs with multiple taps to select the desired bias voltage
Cheers
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 30th August 2011, 12:04 PM   #272
10y is offline 10y  Italy
Hi Luca,
pcbs well received !
Thank you,
Anto
Old 30th August 2011, 06:30 PM   #273
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Cheers
Ale
Hi Ale
Can you post a few more pics of you breadboard??
Cheers
If you keep digging in the garden of failure you will eventually find success
Old 18th November 2011, 10:21 PM   #274
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Just to be sure. Pic in post #264 shows potmeter in wrong position. Only p100 and p200 should be used if just the cascode CCS is utilized.
Old 6th December 2011, 07:58 AM   #275
regal is offline regal  United States
Board received, thanks. Was not expecting the gyrator option. Very nice.
Old 6th December 2011, 09:10 AM   #276
gyrator option
I don't think a VCCS is the same as a gyrator. That said. I still don't understand why one would choose a VCCS over a CCS?
I did read this thread: Anti-Triode SEPP, how to do best?
But still not clear what applications this is suitable for.
cascoded bjt ccs - design check please aardvarkash10 Tubes / Valves 12 17th December 2010 09:07 PM
LTP CCS IXYS with 10m45s opinions aroS3 Tubes / Valves 7 30th May 2009 02:47 AM
IXYS 10M45 CCS IC question zobsky Tubes / Valves 19 26th July 2008 08:15 PM
6SN7 Cascoded CCS korneluk Tubes / Valves 3 25th November 2007 10:02 AM
IXYS 10M45 chip CCS Alastair E Tubes / Valves 3 31st December 2006 12:45 PM
Page generated in 0.11095 seconds (73.90% PHP - 26.10% MySQL) with 11 queries
