| Group Buys Members group buys |
#21 |
diyAudio Chief Moderator
#22 |
Salas
as I understand you do not recommend IRF 240 / 9240 as a hot road but IRF 520 / 9520 ? where can 2sk117GR be sourced |
#23 |
No I don't recommend 'em if you want it to play as intended. 9610/9530 as in BOM. For K117GR Ebay has plenty. For typical shops I did not query.
#24 |
#25 | |
Remote sensing is a good idea Salas, all well done :- )
Thanks Quote:
#26 |
not politcally affiliated
If it helps-I can order a good deal of the 2SK117 GR's. I should be able to sell them for .50-75 cents each. I am also considering getting some of the needed transistors, and 1/4 W 1R resistors on hand, as these seem to be PITA parts to locate for some. I would not mind a show of hands so to speak what and who would like this.
DCB1/BiB Sign up Sheet Round #2 2012 CLICK HERE|SSHV2 Shipping| F5TConvertible Circuit Board Sign Up Sheet (Shipping)CLICK HERE|Semisouth R100A/R085 available PM |
#27 |
I put for two boards in the spreadsheet, I would be interested in any of the hard to get parts you can supply.
#28 |
I have put a copy of the build guide here.
https://docs.google.com/document/d/1...thkey=CM7d-IkL The formatting may not be perfect. but it's up there.
#29 |
I have found a seller that has the 2sk117 and diodes, pots some fets etc for good prices with low shipping charges, I have used them before and recommend them. Tayda Electronics Home Page. Pitty the irf9540 is not recommended, they don't have the IRF9530, but have most all other semis.
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert |
#30 |
Will play with 9540s too, but the Zo bandwidth will close in and curve up a bit. On the other hand the minimum Zo will be 20% less. If you have and want to put, you can certainly see for your self.
| OLD THREAD Salas low voltage shunt regulator (V 1.0)for DAC | quanghao | Quanghao Audio Design | 15 | 16th July 2010 05:05 AM |
| Wtd: Salas shunt reg boards | RichLund | Swap Meet | 1 | 23rd April 2010 10:28 PM |
| Ikoflexer's advanced shunt regulator (GB thread) | Bas Horneman | Group Buys | 8 | 30th March 2010 12:12 AM |
| Modified Salas Mosfet Shunt Reg | mach1 | Tubes / Valves | 2 | 18th December 2008 05:36 AM |
| Page generated in 0.08759 seconds (71.14% PHP - 28.86% MySQL) with 11 queries |
