| Group Buys Members group buys |
#971 |
diyAudio Chief Moderator
Just maybe, without C/W data and ventilation of that ''box sink'' there is no scientific answer, but there is a rule of thumb, if you will measure more than 70C on the actual metal tab of any Mosfet its not long term reliable. Apply high quality thermal paste, it helps.
#972 |
All arrived here Mike. Thanks very much.
John |
#973 |
Then i can maybe sink one of the regulators at case bottom, and the other regulator gets its own sinks.
Will be pretty much stuff in the case, since it's a parafeed tube line-stage w. buffalo dac and i/v-stage in the same case. Mike, i missed two 1R resistors in my IRF- set of components, no problem though, since i will still need to order a few parts for voltage-set part. When this +-15v regulator will feed my I/V stage, would it be recommended using a 220u electrolytic instead of an 10uF film-cap for C101/C201? And is it better running 2x1,7v leds instead of a zener? |
#974 |
Mine arrived a few days ago, FYI
![]() Thanks heaps ! Now to find time to put them to use ... |
#975 | |
#976 |
Dimitris
Just received the BiB boards and the minikits. However no DCB1 parts or board. Did you send these in a separate package Mike?
#977 |
not politcally affiliated
Due to lack of boards, I have added a new sign up spreadheet to my signature.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#978 |
Safe and sound, received in Norway
Thanx P. |
#980 |
Dimitris
Mike I am measuring the green leds from the minikits at ~1,84V and the reds ar about 1,7V is that right? or am I doing something wrong? I expected something ~2,1V and 1,9
| GB: Salas Shunt for Squeezebox | mravlca | Group Buys | 8 | 18th July 2011 04:34 PM |
| My PCB design of Salas SHunt Reg | Lazybutt | Power Supplies | 24 | 14th July 2011 04:11 PM |
| Wtd: Salas shunt reg boards | RichLund | Swap Meet | 1 | 23rd April 2010 10:28 PM |
| Modified Salas Mosfet Shunt Reg | mach1 | Tubes / Valves | 2 | 18th December 2008 05:36 AM |
