Group Buys Members group buys
GB Thread for Salas SSLV1.1 BiB shunt reg
Old 29th November 2012, 02:32 AM   #1111
king4joy is offline king4joy  Hong Kong
Originally Posted by Tea-Bag View Post
Guys, here is the link for the next GB. I dont have any extra stock of boards. I do have extra minikits if needed. Please post what you want. the quicker we get to ~100 boards, the sooner I will order more.
https://docs.google.com/spreadsheet/...3VVk1Znc#gid=0
King, I am not sure which one you edited, but please use the one above.
Thanks.
Tea
I have put my name down for 1 set of boards, and 2 minikits....
Is the mini kit suitable for my application: 6.5-7.0V out at 1.5A pluse safty margin...Salas suggested me to use IRF9530
Thankyou,
King
Old 1st December 2012, 02:59 AM   #1112
Hi TeaBag...what are the things included in the IRF+minikit; ??
and the SSHV2 full kit please?? does this include heat sinks??
Thankyou,
King
Old 1st December 2012, 04:45 AM   #1113
KlipschKid is offline KlipschKid
Hey king,
For technical questions, you need to go to the development thread. This is the i-want-to-buy-only thread.
Details of the kit are here :
http://www.diyaudio.com/forums/blogs...-minikits.html
It doesn't mention heatsinks at all because that's for the builder to determine according to their current demands, so it's not possible to include correct heatsinks.
Quote :
"What is NOT included.
No caps, connectors, pots or resistors for set adjustment. No Rx01 resistor, rectifier diodes or stand off screws. No PCB, that's seperate
Mica and small bolt washers are included. The mica may break in transport. Forgive me.
Positive Rail IRF+ (5.5V-45V)
5-2SK117GR
4-Green LEDs
6-Red LEDs
2-Multicomp 1R resistors 1/4W MF 50ppm
2-270R PRP 9372 TC25 1/4 MF 25ppm
1-47R PRP 9372 TC25 1/4W MF 25ppm
1-IRF9610
1-IRF9530
1-BC550C
Negative Rail - IRF- (-5.5v-45v)
5-2SK117GR
4-Green LEDs
6-Red LEDs
1-BC560c
1-IRF610
1-IRF530
Positive Low Voltage BJT+ (2.5-5.5v recommended)
5-2SK117GR
4-Green LEDs
6-Red LEDs
1-27R PRP 9372 TC25 1/4W MF 25ppm
1-IRF9610
1-MJE15029
1-BC550c
Negative LV Rail. BJT- (-2.5-5.5V RECOMMENDED)
5-2SK117GR
4-Green LEDs
6-Red LEDs
1-IRF610
1-MJE15030
1-BC550C"
Old 1st December 2012, 05:43 AM   #1114
KlipschKid ...thankyou....
Old 1st December 2012, 05:57 AM   #1115
Is it correct that the +IRF mini kit includes 2 extra 2SK117GR, 1 extra Green LED. and 4 extra red LED for each board please??
5-2SK117GR (Q102,103,105...plus 2 extra?)
4-Green LEDs (D102,103,104...+1 extra?)
6-Red LEDs (D105,106 plus 4 extra?)
2-Multicomp 1R resistors 1/4W MF 50ppm (R104,107)
2-270R PRP 9372 TC25 1/4 MF 25ppm (R102,106)
1-47R PRP 9372 TC25 1/4W MF 25ppm (R108)
1-IRF9610 (Q101)
1-IRF9530 (Q106)
1-BC550C (Q104)
Old 1st December 2012, 01:09 PM   #1116
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
King, the extra LEDs are for mix and matching if needed green and red. There is enough to do all in red if needed. Instead of lowering power resistor, one can use 4 green LED's and the CCS will heat right up! They run ~2v were the reds ~ 1.85 v each.
The full SSHV2 kit list is here.
SSH FULL KIT - Does not include board And no BIG heatsink for IRF840
2-20ma Red LED's
2-Supertex DN2540
1-IRF840PBF
2-Fairchild KSA1381ETSU
2-TO-220 Mica Insulator
3-12v 1/2W Zener
2-Keystone plastic washers
2- Welwyn 68K 2W 50ppm
1-KOA M/F 1/4W 100ppm 1.82R*
1-T93YA Vishay/Fernice trimmer 1/2W 100ppm 200R
1-T93YA Vishay/Fernice trimmer - 1/2W 100ppm 1K
3-271 Series Xicon 1/4W 50ppm 100R
1-271 Series Xicon 1/4W 50ppm 10R
1-271 Series Xicon 1/4W 50ppm 1.8k
1-271 Series Xicon 1/4W 50ppm 470R
1-271 Series Xicon 1/4W 50ppm 220R
1-Molex 4P Fixed Terminal Block Black
1-TE Connectivity 2P Terminal Block
2-274-1AB Wakefield TO-220 Heatsink
1-647-10ABP Wakefield TO-220 Heatsink
1- Solen 10UF 400v Film Cap
1-Solen .33uf 630v Film Cap
I have a couple of these in stock, but no boards to go with them.
Salas Boards GB 2017#1 SHIPPED | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards In Stock
Old 3rd December 2012, 08:49 PM   #1117
rsotirov is offline rsotirov  Canada
The package arrived today in good condition.
Thank you Tea Bag and Salas.
Roumen Sotriov
Old 6th December 2012, 08:26 AM   #1118
Tea-Bag....with the +IRF mini kit....can I have IRF9530 instead of IRF9610 for Q101; or can I buy one more of IRF9530 please??
Old 6th December 2012, 10:39 AM   #1119
Tea-Bag's Avatar
I can get you what you want. But have you run that by Salas, to make sure it will operate okay? Sound familiar, but I am not certain. PM me what you want and I will get it over to you.
Old 10th December 2012, 04:18 PM   #1120
Catal is offline Catal  Italy
The parcel arrived today.
Thank you very much Tea Bag and Salas.
Frank
GB Thread for Salas SSLV1.1 BiB shunt regHide this!Advertise here!
GB: Salas Shunt for Squeezebox mravlca Group Buys 8 18th July 2011 04:34 PM
My PCB design of Salas SHunt Reg Lazybutt Power Supplies 24 14th July 2011 04:11 PM
Wtd: Salas shunt reg boards RichLund Swap Meet 1 23rd April 2010 10:28 PM
Modified Salas Mosfet Shunt Reg mach1 Tubes / Valves 2 18th December 2008 05:36 AM
Copyright ©1999-2017 diyAudio
