GB Thread for Salas SSLV1.1 BiB shunt reg - Page 102 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 2nd October 2012, 11:26 AM   #1011
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Carsten, use 2 red or green ~1.9V leds and one 1N4007 or alike diode with its cathode mark reverse to the zener's cathode printed in the 'see text' area. Jumper all unused positions in that area, and even the Mosfet will do it. Check with dummy first not to kill any sensitive digital, it should be pretty stable and near 5V.
Old 2nd October 2012, 11:32 AM   #1012
Interesting Salas, the BiB guide recommends the two red LED's and a 220 resistor which worked quite well for me. Does changing the resistor for a forward biased diode make it quieter or more stable perhaps? I'm thinking of changing to it. (I'm also supplying circa 500 mA at 5 v)
John
Old 2nd October 2012, 11:47 AM   #1013
Salas's Avatar
Hmm, resistor damps it a bit which is a plus for the filtering, I suggested the diode as a quick alternative to Carsten for checking all is well with his Mosfet sample and 5V. With the resistor if the Jfet CCS chances to be a bit happier takes a couple of iterations if not allowed to pass 5V. As for the drift when the 220R contributes only 0.6V the diode's stability gain for warm up will be rudimentary. You can try it if you think you may pick it up subjectively and choose though. The impedance of the ref would change a bit mainly, noise no, the lytic filters hard and the Johnson of a 220R is peanuts.
Old 2nd October 2012, 12:10 PM   #1014
Thanks Salas, not a "cut and dried" improvement then but who knows I'll give it a go and see what if anything it does subjectively. I had no difficulty holding the 5 volts steady but I was careful to select the 2SK117's as per the guide. Supplies as Squeezebox Touch quite comfortably and gives an audible improvement on the supplied Switch mode wallwart.
John
Old 2nd October 2012, 12:18 PM   #1015
Salas's Avatar
Let us know in due time in the builds thread then.
Old 2nd October 2012, 04:18 PM   #1016
carsten.witt's Avatar
@Salas,
sorry, my english is not the best and i understood not all.
I think i must use the BJT package with your explanation or i am wrong (appendixes 1 part b)?
Old 2nd October 2012, 04:38 PM   #1017
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Originally Posted by carsten.witt View Post
@Salas,
Carsten, I can ask my friend Gerd to translate for you in Private message between us.
Salas Boards GB 2017#1 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Out of stock
Old 2nd October 2012, 04:41 PM   #1018
Thanks, that would be fine!
Old 3rd October 2012, 09:27 AM   #1019
@gerd,
thanks for your help.
Old 3rd October 2012, 10:56 AM   #1020
Stixx is offline Stixx  Germany
Stixx's Avatar
I am happy to help as well since I just finished a 5V Mosfet SSLV ( and have it working to power JP's ES9023 DAC).
Just shoot me a PM (schreib' mir einfach eine PM )...
GB: Salas Shunt for Squeezebox mravlca Group Buys 8 18th July 2011 04:34 PM
My PCB design of Salas SHunt Reg Lazybutt Power Supplies 24 14th July 2011 04:11 PM
Wtd: Salas shunt reg boards RichLund Swap Meet 1 23rd April 2010 10:28 PM
Modified Salas Mosfet Shunt Reg mach1 Tubes / Valves 2 18th December 2008 05:36 AM
Copyright 1999-2017 diyAudio
