Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 18th August 2012, 09:51 AM   #1001
I already tested that converter with battery and dont want anything worse, just more practical.
Old 18th August 2012, 10:05 AM   #1002
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Then wait to get your kit, get your trafo, diodes and 10.000uf/25v cap meantime to feed your dc-dc converter not to have the recharge headache, and you recycle those main parts for the sslv1.1 later.
Old 18th August 2012, 10:06 AM   #1003
Ok chief. thanks for advice
Old 21st August 2012, 05:08 PM   #1004
Can I use these diodes instead of MUR860? I heard these are replacement of MURs:
http://www.datasheetcatalog.org/data...wte/ER801A.pdf
ER806 to be more precise.
Old 21st August 2012, 06:03 PM   #1005
Salas's Avatar
They will work, not doubt, but look for soft recovery models is better if you can find.
Old 22nd August 2012, 05:07 AM   #1006
roender is offline roender  Romania
roender's Avatar
One can insert a 1ohm in series with every diode in order to get rid of most part of switching noise
Or, insert 2-10ohm resistor between + of the bridge and + of reservoir capacitor
Old 23rd August 2012, 03:05 PM   #1007
Can I use IRF9630 instead of IRF9610?
Old 23rd August 2012, 05:33 PM   #1008
Salas's Avatar
Yes, but you will make the CCS somewhat slower.
Old 17th September 2012, 05:22 PM   #1009
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Update:
I just ordered more of the PRP resistors for the kits. They will be due 10-20. So I plan on closing the GB at the end of October, assuming the numbers are 100 plus for the boards.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE
Old 2nd October 2012, 11:01 AM   #1010
carsten.witt's Avatar
Hi all together,
i want to power up the WaveIO (USB/I2S) from Lucian with one regulator (ca.500mA).
My question, is it possible with the parts from the GB "IRF (5.5V-45V)" to get/adjust the 5V for WaveIO or should i better use the "BJT (2.5V-5.5V)" package?
For my other components, "BlackCrow" and mojo2, is it clear for me (1 x 12V, 2 x 18V).
Thanks and Regards ........Carsten
GB: Salas Shunt for Squeezebox mravlca Group Buys 8 18th July 2011 04:34 PM
My PCB design of Salas SHunt Reg Lazybutt Power Supplies 24 14th July 2011 04:11 PM
Wtd: Salas shunt reg boards RichLund Swap Meet 1 23rd April 2010 10:28 PM
Modified Salas Mosfet Shunt Reg mach1 Tubes / Valves 2 18th December 2008 05:36 AM
Copyright ©1999-2013 diyAudio
