DX Blame Group Buy - Page 41 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 19th May 2011, 10:36 PM   #401
jprco is offline jprco  Canada
Rudi, I would check again to make sure that none of heat sink mounted transistors have shorted to it. As I mentioned earlier, the MJE's I was using both shorted to the heat sink.
You know what damage can occur if you power up under such a condition!
Good luck finding the problem,
Jean
Old 20th May 2011, 02:50 PM   #402
use a bulb tester at every intermediate stage of construction. It allows safe and damage free power up. Then (while the bulb is glowing and mains power still plugged in) measure where the excessive current is escaping.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th May 2011, 03:04 PM   #403
Rudi_Ratlos's Avatar
They call me "Mr. Bulb", Andrew:
Bild: bulk00398x8.jpg - abload.de
I use a High Voltage Halogen lamp, 40W.
I think, that the problem I am having, is home-made.
I bought a couple of Toshiba KSC5171 and KSA1930 from an ebay-seller (Hongkong) and used them as VAS (KSC5171) and drivers.
I measured the Hfe of a KSC5171 yesterday and my DMM showed a value of 65.
I wonder, if they are counterfeits.
I have already begun to replace them by BD139 and MJE and will power on again - of course with assistance of the bulb tester.
Best regards - Rudi_Ratlos
Old 20th May 2011, 03:38 PM   #404
Dear DX Blame friends,
I really recommend you something like this:
BULB tester
Price: 5
Function: delimits the output of your transformer to approx. the Watts value of the lamp
Howto: insert the lamp in serial with one of the main's wires of the transformer
Benefit: prevents your precious transformer (and yourself) from "suffering" a short on your AMP PCB
Old 21st May 2011, 02:40 PM   #405
boring is offline boring  Singapore
Any more boards available? I need:
2X amp boards
2X PSU
2X speaker protector
Thanks!
Old 21st May 2011, 08:24 PM   #406
Sorry, there are no PCBs left.
Old 2nd January 2012, 03:29 PM   #407
Hi Rudi, am putting finishing touches on DX ST amp and am using only one transformer. Is it better to run one power supply board for both amp boards or to run two power supply boards, and just conneting the AC inputs of transformers to both power supply boards. Will this make any difference. Appre iate again your effort in making the boards.
Best, John
Old 3rd January 2012, 06:53 AM   #408
Hello John,
there are 2 ways to do the setup.
First way: 1 transformer and 1 PSU, feeding the power to both of the AMP PCBs, and the second way: 2 transformers and 2 PSUs, each one feeding one AMP PCB.
The first way is more economic, saves space and is - in case the transformer and the reservoir capacitors are big enough - in most cases adequate.
I use the second way - I call it dual-mono setup -, if I feel that the AMP is "worth it".
In this case the power consumption of one channel does not affect the power consumption of the other channel.
According to my ears the DX BlameES with 2 big SANKEN output-transistors was worth a dual-mono setup.
I do not know the DX BlameST, so: it simply depends on your ears and on your feeling.
Best regards - Rudi
Old 9th January 2012, 12:40 PM   #409
Thanks Rudi, I set it up with one transformer and seems to be working nicely on the bias. I had trouble on one channel and fooled around with the trim pot and found that it was broken, replaced it and they both channels bias nicely now. I have 100 R in place of the fuse and adjusted for 10 mv, or should this be 4.7 -6 mvolt as you put in the builders manual. Once I know this then I will cut out the resistors and put in fuses and speakers and try it out.
Cheers, John
Old 9th January 2012, 12:43 PM   #410
I believe I saw that Carlos adjusted for 10 v with 100 R and 4.7 with 47r over fuses on you tube but not sure which is correct or if it matters too much. However I want to make sure it does not go up in smoke b y too much and am only self taught in these things. thanks again, John
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Dx Blame ES .... based into the Blameless, i am trying a new amplifier destroyer X Solid State 1826 12th February 2011 07:11 AM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 10:26 AM
Tuning the DX Blame amplifiers, for newbies... smartx21 Solid State 3 15th May 2010 04:56 PM
Copyright 1999-2017 diyAudio
