Group Buys Members group buys
DX Blame Group Buy
DX Blame Group Buy
Old 4th May 2011, 04:24 PM   #391
Art M is offline Art M  United States
Default Biasing output
Originally Posted by jprco View Post
With the changes in various fixed resistors on the MKII supercharged, what are the accepted values for quiescent current (60-100ma ?) .
Jean
I strongly suggest you you look at the advice for adjusting quiescent levels in the book by Douglas Self (i.e we don't adjust for quiescent current ). This amplifier is a HIJACKED version of his design with trivial modifications.A lot of the advice given here regarding it's operation is just plain incorrect
Old 8th May 2011, 09:15 PM   #392
jprco is offline jprco  Canada
Default Voila!
Rudi, Carlos: Completed 2 boards, MKII Supercharged and as expected, they sound greatttttt. I attach a photo and hope it comes through ok.
A couple of assembly notes:
1- mounted the damping coils underneath just for looks,
2- had some problem like Rudi had with shorting to heat sink but with the MJE's not the BD - poor quality shoulder washer or tightened to much!
3- must remember to mount the board MJE with correct pin allignment- board shows BD139 layout.
4- Opted for a trimpot and the MKII lineup for C19/C20 in the end. Also I might get just away using the 10000uf/63V so far so good. If not I'll add a pair off board.
Great project, now I wonder what design to go with for the other 2 boards.
Thanks again for all your help.
Jean
Old 8th May 2011, 10:01 PM   #393
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Congratulations and thanks Jprco
Thank you by the nice picture and your opinion about.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 9th May 2011, 05:38 AM   #394
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Jean,
nice job! Thank you for the picture.
Sorry. I forgot to mention in my Builder's Manual that you have to flip Q7 by 180 degrees if you do not install an ECB transistor (like BD139) in this place.
You will receive strange results else!
Enjoy the music now.
Best regards - Rudi_Ratlos
Old 12th May 2011, 08:00 PM   #395
Jean,
I have adjusted the quiescent current, I still have to solder some cables, and then, tomorrow, I will have a big whisky and listen to my DX Blame MKII
(left channel only) for the 1.st time.
Click the image to open in full size.URL]
Old 15th May 2011, 12:21 PM   #396
Default Strange things happening
Dear DX Blame friends,
after adjustment of the quiescent current (to about 50mA) and measurement of the DC voltage on the speaker's output (between 3 and 6 mV),
I powered up the 1st channel of my DX Blame MKII:
and - Aaarrrgh: Smoke coming from the PCB.
I forgot to unsolder the 100 Ohm resistor, that I used during the adjustment procedure, and this resistor melted away .
The fuse, that I inserted into the fuse-holder after my adjustments have been completed, is 2A. I measured it; it is o.k.
This should have never happened, because the current is flowing through the fuse now!
I am using 15.000F power caps, and the power to the PCB is currently delimited to <60 Watts by means of my light bulk tester.
These things are very strange.
Has anybody an explanation for what is happening?
Old 15th May 2011, 04:12 PM   #397
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Rudi,
I think it's the current that those powersupply caps are drawing when you fire up the amp the first time.Insert a 5watt 0.1 ohm resistor inline with the DC rails
Old 15th May 2011, 05:09 PM   #398
Patrick,
I have been able to adjust the quiescent current according to Carlos recommendation, I measured very little (2-7mV) DC on the output, ...,
the AMP worked as designed during the adjustment phase.
When I connected a source and a speaker to it, something happened.
Moreover: I am currently no more able to adjust the quiescent current to "low values" (about 50mA).
The minimal quiescent current, that I can achieve when I turn the BIAS trim poti to its maximal value (500 Ohm), is about 80mA.
This is strange as well.
I did a mistake somewhere. But currently I have no idea, where.
Old 16th May 2011, 07:52 AM   #399
Default DIY picture of the month ...
... or re-definition of Ohm's Law.
The rail-current is not flowing through the fuse (which is intact) - that would be too easy -, but through the 100 Ohm resistor,
that I used during the setup procedure, and melts the resistor.
I measured the fuse afterwards: it is o.k.
http://www.abload.de/img/fusexey2.jpg
Old 16th May 2011, 10:28 AM   #400
Default Soon you will find the bug...check AC voltage in the output terminals
Maybe you gonna need more compensation because of different transistors and different board.... if you obtain AC in the output, without signal entering, then increase the Miller capacitor till this stops.
Good luck.
regards,
Carlos
DX Blame Group BuyHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Dx Blame ES .... based into the Blameless, i am trying a new amplifier destroyer X Solid State 1826 12th February 2011 07:11 AM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 10:26 AM
Tuning the DX Blame amplifiers, for newbies... smartx21 Solid State 3 15th May 2010 04:56 PM
Copyright ©1999-2017 diyAudio
