| Group Buys Members group buys |
#41 |
Thanks, looks like I can get a set from there. Those caps are indeed the perfect fit for this board.
#42 |
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB / SSHV-Shunt PCB
Stock status in my Blog |
#43 |
#44 |
The perfect fit Oliver.
#45 |
Oliver,
Those are just beautiful. I've got 8 coming my way, yippee! I've often thought about cutting the traces between the + section of the 4700uf caps and throwing in chokes with very low DCR. What say you Salas? Anand. |
#46 |
dvb-projekt - 4 pcs.
janpo - 4 pcs. sandbasser - 4 pcs. CeeVee - 4 pcs. number9 - 4 pcs. CxTurbo - 4 pcs. Marra - 8 pcs. merlin2069er - 4 pcs. AlanElsdon - 4 pcs. nycavsr2000 - 8pcs. All orders are dispatched!
#47 |
diyAudio Chief Moderator
If they are uH value and compact to solder underneath its OK for cutting very high frequency gremlins from the diodes. If big like speaker coils, will need cabling that will widen the loop area making it more of an antenna and may offset the benefit.
#48 | |
Better to just use a good common differential choke in the AC line in which is what I will do (as I do in most of my dac or preamp projects). Something like Audio Circle's Felix filter. Anand. |
#49 |
Sounds like a good plan.
#50 | |
http://industrial.panasonic.com/www-...AEL0000CE7.pdf |
| Salas hotrodded blue DCB1 build | wendell c | Analog Line Level | 3078 | Today 11:40 AM |
| Mundorf M-Lytic and Silver-in-Oil Capacitors | kmtang | Tubes / Valves | 19 | 4th January 2011 06:58 AM |
| Pair of Mundorf M-Lytic Si 10,000uF 50V (UK) | nad | Swap Meet | 1 | 20th January 2010 08:57 PM |
| FS: Black Gate "F" and "Nonpolar" caps | gripracer | Swap Meet | 3 | 10th December 2009 07:31 PM |
| What makes Nichicon "muse"/"for audio" caps different ? | percy | Parts | 2 | 3rd October 2009 05:53 PM |
