Group Buys Members group buys
GB: New run Lynx 3.01 amp by Jan Dupont
Old 1st September 2010, 06:49 AM   #41
Tarasque is offline Tarasque  Netherlands
Tarasque's Avatar
Hi Sakis,
I still have 4 boards reserved for you. Do you still need them?
WWW.DelftAudio.com
Old 1st September 2010, 07:04 AM   #42
Tarasque's Avatar
Originally Posted by AndrewT View Post
for every "circuit" that has a flow and return route then the pair of flow and return must have a low loop area to minimise pick up of interference from other noisy sources and to minimise the radiation of interference from this circuit.
Where the flow and return involve three wires (as in a dual polarity supply to an amplifier), all three wires must be formed into a triplet with low loop area.
Twisted is the easiest way to achieve low loop area and low interference with wiring.
Parallel close space traces on a PCB achieve similar.
Hi Andrew...I typically braid the power wires to the power stage. In my latest designs of cases I managed to keep the wires from the power caps to the power stage below 7cm.
I also made a pass X350 and used an L shaped aluminium bracket of 150 x 100 mm and 10mm thick to couple the power stage to the heatsink. . On top I mounted the power stage and on the other side the power cap PCB. I ran the wires through the bracket and kept the wires under 3cm. At the same time I had the speaker terminals close by as well. The L-shaped bracket is also used as groundplane as the 2 L shapes are interconnected at the star ground.
When driving loads under 2 ohms, this arrangement is key...especially when currents of over 20A were observed.
WWW.DelftAudio.com
Old 26th May 2011, 07:59 AM   #43
sunil is offline sunil  India
Default Boards availability
If it is possible to get boards for this project I would be interested. Please pm or send me a message. Thanks.
Old 6th June 2011, 08:55 PM   #44
adnankhan is offline adnankhan  Pakistan
what is the diffrence between version 3.0 & 3.01 ??? can anybody tell???
Old 15th February 2012, 05:39 AM   #45
Default Boards for sale
I have a pair of these boards (Lynx ver 3.01) for sale.
I'm selling because I 've bitten more than I can chew. I was building a P3A (Rod Elliott) and didn't realize how much power this really is - 150/275/450 @ 8/4/2 ohms
I'm very happy with the P3A. The cost of the heat-sinks, case, transformer here in India may net be worth the trouble, not to add the difficulty of getting the 16 transistors required.
I paid 17Euro each (42 for the pair with shipping) and have a stereo pair for sale.
Please see links for additional info.
http://www.diyaudio.com/forums/solid...-s-thread.html
Old 18th February 2012, 09:39 AM   #46
Default Lynx 3.01 boards
Ping....no takers ?
Old 18th February 2012, 11:28 AM   #47
johngalt47 is offline johngalt47  United States
I clicked on Jan's link to the assembly guide but got the 404 error.
I'm interested in this amp if all the components are available.
Any technology sufficiently advanced is indistinguishable from magic
Old 18th February 2012, 01:50 PM   #48
Are you after the boards or just the doco. I've attached the doco if it is useful.
Sunil
Old 18th February 2012, 02:14 PM   #49
If the documentation is available then I'm interested in the boards.
GB: New run Lynx 3.01 amp by Jan DupontHide this!Advertise here!
Power Amp PSU Board (for e.g. LYNX Amp) Jan Dupont Group Buys 466 20th May 2017 02:21 PM
LYNX amp problems...Help JojoD818 Solid State 210 11th May 2015 04:34 PM
DELTA PA-34A Power Amplifier by Jan Dupont MEGA_amp Solid State 8 21st January 2005 07:30 PM
Copyright ©1999-2017 diyAudio
