"Reference" TDA1541A DAC with I2S-BUS architecture - Page 88 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 82 47.95%
Immersion Silver 49 28.65%
Immersion Tin 23 13.45%
OSP - Organic Solderability Preservatives 17 9.94%
Voters: 171. You may not vote on this poll
Old 18th November 2012, 11:46 PM   #871
Originally Posted by qusp View Post
wouldnt the i2s fifo buffer plus the i2s/PCM universal driver be the ticket?
I own a LOT of i2s convertors and this one PWNS them all. you could add a USB convertor if you absolutely need USB, but the way this works it essentially marries whatever source you are using to the dac. you can use his spdif add on module, or any USB->i2s you like and as long as you dont need higher than 192kHz (the spdif coax will do 216, but only the i2s does 384khz) there really isnt any difference at all, its agnostic in that regard.
you can also use his galvanic isolation board between the fifo buffer board and the clock board, which then isolates the dac from any and all noise on power or ground (USB ground for example), then leaves only the clock jitter plus that of the clock buffer as the total jitter output. so the source and transport IS the dac itself so to speak
IMO it really doesnt leave much room for improvement and the daughterboard actually allows driving the TDA directly...
Thanks qusp. I took your advice and made the "adjustments" on the I2S signal/ground you recommended. MAJOR improvement. I had to alter The Red Baron DAC board (drilled a hole to access the I2S inputs and grounds from underneath). The bass is back, midrange richness is there as well.
Could you please tell us which parts we'd need if we wanted to utilize USB input with the Ian boards? I'm trying to get some technical info and it seems that i keep bouncing around on the group buy threads....
Old 19th November 2012, 11:03 AM   #872
I found most of what I think I need on Ian's boards. Will sift through it now...
Old 19th November 2012, 11:42 PM   #873
neda is offline neda  United States
neda's Avatar
[QUOTE=crobbins5421;3247000]Thanks qusp. I took your advice and made the "adjustments" on the I2S signal/ground you recommended. MAJOR improvement. I had to alter The Red Baron DAC board (drilled a hole to access the I2S inputs and grounds from underneath).
Hi crobbins5421,
Can you explain exactly what adjustments on the I2S signal/ground you made,
and how? I'm very curious.
Old 19th November 2012, 11:53 PM   #874
Check my post (#867). This will give you some very helpful I2S background info (with the link).
I basically drilled through The red Baron dac board after wrapping the I2S (signal) wires with ground wires.
I'll post a pic soon.....
Old 20th November 2012, 01:16 PM   #875
Default Red Baron/Amanero Picture
Here's a picture that will hopefully explain it....
I drilled through the DAC board and attached the I2S ground wires to the grounds of the small Wima caps underneath....
Old 20th November 2012, 01:53 PM   #876
neda's Avatar
Looks good! Where do the orange/white wires from your star ground point lead to that are going under the dac?
How quiet is it? Any hum or hiss at full volume?
Old 20th November 2012, 02:15 PM   #877
The orange/white wires are the ones that run to the grounds on the small Wima caps.
I've got a "wee bit" of hiss. That will be corrected with a USB isolator....
Old 17th December 2012, 11:58 PM   #878
Default Still correcting grounding issues...
Question for the followers of this fine hobby (obsession)....
What is the preferred method for star grounding? I thought I had it correct, and I'm still getting this weird intermittent hum...
I'm powering my USB to I2S converter with Oliver's (Salas) 3.3V shunt. I lowered the current limiting resistor to 10R to get more current. The problem lies in the fact that when there's no music playing there's almost no hum or hiss. When music is playing (on some songs/cd's) there is some hiss or static. Here's where it gets weird...when I touch the 3.3V board (or caps or heat sinks or anything else) the hiss and static gets much louder.
All component boards rest on a wood board. Comments?
Old 24th December 2012, 12:28 PM   #879
freax's Avatar
if the wood is even remotely moist it can carry hum to a part of the circuit which is most susceptible to it.
could also be close proximity to the transformers that is causing it
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 29th December 2012, 01:08 PM   #880
Default Red Baron mods to work with 3.3v USB/I2S
In doing some "light reading" in the ecdesigns thread, I stumbled on this post where John gives resistor values to modify the I2S attenuator to work with 3.3v I2S signals:
Building the ultimate NOS DAC using TDA1541A
Thoughts?
I bring this up as I am auditioning different USB to I2S converters and currently use Oliver's High Speed Buffer with very good success...but might it be a better solution to ulilize the 3.3v output directly?
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 11:20 AM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
Copyright 1999-2017 diyAudio
