Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
View Poll Results: Surface Finish for future PCB´s
ENIG - Electroless Nickle/Immersion Gold 41 43.62%
Immersion Silver 30 31.91%
Immersion Tin 15 15.96%
OSP - Organic Solderability Preservatives 8 8.51%
Voters: 94. You may not vote on this poll
Old 8th July 2012, 03:43 PM   #841
acccruz is offline acccruz  Portugal
Default Salas Shunt Reg Capacitors
Hi to all:
Please let me know your opinion about use Panasonic FM 220/35 on Salas Shunt reg.
I´m unable to find Rubycon ZA 220/35, but I have in my hands 10 of 330/35 - it´s critical if I use them?
Many thanks for your help,
Antonio
Old 8th July 2012, 03:46 PM   #842
UV101 is offline UV101  England
UV101's Avatar
I've used Panasonic FM in my amplifier as they have slightly higher voltages available. ZA are obsolete but I've been using Rubycon ZLG in place of ZA on most things with excellent results. Best of all, they are a fraction of the cost ;-)
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 8th July 2012, 03:51 PM   #843
Just one more question please:
What about your opinion about Rubycon ZL or ZLH? It´s more easy to find it on eBay than the ZLG!
Thank you!
Old 14th October 2012, 07:52 AM   #844
freax is offline freax  Australia
Owner and operator of irc.tenettenba.info
freax's Avatar
Hi I'm considering constructing one of these DAC boards + Optical to I2S converter (Opus WM8804) in the same 1U project box (1U high, 10 inches deep), however.
I need it ALL to run from 12v-13.5v DC (Float SLA voltage) as I would like to use it in a mobile studio setup and I like to have my equipment run from a DC UPS system. So, wasting as little amount of power as possible on capacitors and linear regulators would be ideal. Also noise is an issue...
Can I get some suggestions on what to use for a DC-DC converter which would be suitable for the dac?
Btw I've tried finding the schematic in the thread, but the link is dead?
Also, seeing as I'm super-poor I was hoping for a cheap buffer stage kit too, any suggestions on what to use for that? Transistor is fine, though a starved heater buffer stage would be nice.
I should also add that I do not have much experience with DAC's, however I can build complex kits within an hour or so, I feel confident in tackling this project, its just that budget and enclosure constraints are limited.
Old 14th October 2012, 08:46 AM   #845
freax's Avatar
Nevermind, I just found out about the red baron, far better and more compact for what I want, imho.
Old 19th October 2012, 11:53 AM   #846
Default Red Baron connection to Tube-I-Zator
Hi everyone.
I'm finishing up the Red Baron dac board. I'm already running the Tube-I-zator (latest version and the 1st generation dac board).
I'm not installing the MOSFET Buffer I/V stage parts, and I see from the pictures that the signal out is then taken from the (L/R) Master/Slave output next to the TDA1541A dac chip on the Red Baron board. Doesn't this need a ref (or ground) as well , or am I not seeing something?
Could it be that the REF is taken from under the Red Baron board to the Tube-I-zator?
Thanks,
Chris
Old 20th October 2012, 09:09 AM   #847
dvb-projekt's Avatar
Send a message via Skype™ to dvb-projekt
Originally Posted by crobbins5421 View Post
Hi everyone.
Thanks,
Chris
Hi Chris,
look here to my grounding scheme:
If you connect it like this with a star GND, you could use the GND of the Tube-i-Zator for the RCA-GND connction.
I hope this answer your question.
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB / SSHV-Shunt PCB
Stock status in my Blog
Old 20th October 2012, 10:41 AM   #848
The screen from the main transformer should connect with a very short lead to the main enclosing metal box (Faraday cage), not a long lead to the star ground (Main Audio Ground).
I don't understand why each regulator has a separated power supply wire from the return supply wire. Surely the flow and return of each regulator should be a twisted pair into the part of the DAC that consumes current.
Note also that all the wires feeding current have no return route associated with them. They must all be circuits and MUST have a flow and return. Showing anything less is confusing.
Old 23rd October 2012, 01:24 AM   #849
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Hi Oliver
Looks like your DAC didnt have any change now
this is the perfect time to start solder
BTW i just have Tubeizator, DAC, shunt & hv (no need supply pcb)
what is the other pcb i need to complete this ?
(i saw a little pcb in the middle of your big picture)
btw BOM this DAC can not see again (look blur) in this thread
maybe you need to attach them
Best regards
Old 23rd October 2012, 04:57 AM   #850
Originally Posted by Pocoyo View Post
Hi Oliver
Best regards
Hi Pocoyo,
the small pcb above the DAC V2.3 is the I2S switch (USB/SPDIF).
All BOM´s you will find in my blog HERE.
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb-projekt Digital Line Level 130 30th January 2011 01:54 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 25.00%)
Copyright ©1999-2013 diyAudio
