Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 88 49.44%
Immersion Silver 49 27.53%
Immersion Tin 23 12.92%
OSP - Organic Solderability Preservatives 18 10.11%
Voters: 178. You may not vote on this poll
Old 8th June 2012, 06:09 AM   #831
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by studiostevus View Post
Oliver, remind me again why that is? Because of the flipflop?
Because one would think that the attennuators would work on 3.3v as well (with lower value resistors).
You could read all about the I2S att. circuit in -ecdesigns- tread HERE.
Originally Posted by skyraider View Post
I never got the attenuators to work with 3.3v from both WM8805 and CDpro2... I ended up discarding the attenuators and use simple grid stoppers...
Correct me if Im wrong, but isnt that the attenuators are to avoid saturating the TDA1541 input? In that case, direct drive with 3.3v should not be a problem?
I had the same problem with my USB to I2S converter. With my UHS Buffer in-between everything works perfect.
Originally Posted by Chilli6565 View Post
Hi Oliver,
I just recieved my Red Baron pcb a couple of weeks back.Do I have to still do the leg change on the output devices or has the board layout changed?
cheers
Paul
Hi Paul,
if you would like to use the onboard I/V you must do the leg change, yes!
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 11th June 2012, 09:31 PM   #832
Chilli6565 is offline Chilli6565  Australia
Default Cannot set to 0v
I am having trouble setting any of the test points to 0 volts ( either the ones on the red Baron board or the ones for setting dc bias on reference board for audio output.
All I get is around -8vdc and very little adjustment...I have checked all the earth grounding and it seems ok...could it be some sort of ground float issue?.
I did originally have the 74hc02 in the wrong way , but corrected it.
The i2s signals come from the cs8414 on the board below.
Is it ok to have only 1 +5vdc supply for the Red Baron?
cheers
Paul
" Digital is only ac anyway "
Old 12th June 2012, 09:01 AM   #833
Ok problem solved..I didnt have the 500 ohm resistors mounted correctly
All measurements ok now...hope it works !?
Old 12th June 2012, 10:42 AM   #834
So now I have plugged it in and.........nothing ....no sound output at all.
i2s from cs8414 to red baron should have been straight forward ??....hhhmmmmm, now what ?
Old 12th June 2012, 08:34 PM   #835
Was thinking about it in bed last night....and the digital ground for the cs8414 is floating ! ( my mistake)...will connect it to common ground later today and see what happens
Old 15th June 2012, 04:26 AM   #836
skyraider is offline skyraider  Malaysia
Got my board working beautifully with the buffer.. I guess its something about the current drive of TTL vs CMOS... the 'zen' in me is still a bit anal about removing the buffers BUT.. this already beats the 'simple' circuits out there by miles.
One thing i noticed, I usually had to use 2nd/3rd order analog filtering. But with the recent board, a simple capacitor bypass to ground is sufficient, the image doesnt get bloated.
Thanks to all for the knowledge sharing!
Old 15th June 2012, 04:40 AM   #837
I now have mine working too.
I had to connect the i2s from the cs8414 to the tda1541 directly...but even then, when it was making music there was still clicking in the sound. It wasnt until I tied the - ( negative) of the spdif before it entered the cs8414, to common ground. After that all was nice and quiet.
Sounds VERY good, although the gain seems to be low?.
Old 15th June 2012, 11:04 PM   #838
neda is offline neda  United States
neda's Avatar
Hi Chilli6565,
Any chance you can post a sketch of this? I'm not a 100% sure I understand
what you've done.
Ned
Old 15th June 2012, 11:46 PM   #839
Originally Posted by neda View Post
Hi Chilli6565,
what you've done.
Ned
I will try and do something today and take some better pics to help explain
Old 16th June 2012, 03:06 AM   #840
Hi Chilli6565,
what you've done.
Ned
Hope this simplistic diagram helps.
I dont know why it worked in my situation, but unitl I grounded the earth/ground of the spdif it didnt work properly.
Normally I have the earth/ground of the spdif floating ?..also I dont use isolation transformer in spdif input.
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 11:20 AM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
