Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBīs
ENIG - Electroless Nickle/Immersion Gold 85 48.57%
Immersion Silver 49 28.00%
Immersion Tin 23 13.14%
OSP - Organic Solderability Preservatives 18 10.29%
Voters: 175. You may not vote on this poll
Old 3rd October 2011, 02:34 PM   #781
studiostevus is offline studiostevus  Netherlands
Hi antonioo, have you done a sq comparison?
I am here: http://maps.google.com/maps?ll=58.921215,5.597375
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 3rd October 2011, 05:19 PM   #782
antonioo is offline antonioo  Netherlands
I have not finished the red baron, i had a hard time finding
Hitachi SK''s.
Previous i had 2 dac''s (green pcb), one wonders off to a friend,
To try out some combination''s need''s a lot off time.
Old 10th October 2011, 12:12 PM   #783
Question to oliver.
The RIV resistors bother me, if i use 2x redbaron, i use 4x 250 ohm.
Is that right??
On your pictures there none.!!
The little ground module- i toke 5v and gnd from dac pcb. on the
output side i have 2 gnd''s??.
My gues is to use audio out-ref , where to put it?
What to do with adjust R''s on Dac and on the small pcb??
Is that double?
Ihope you can help me.
Greetings Ton
Old 10th October 2011, 02:32 PM   #784
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by antonioo View Post
Question to oliver.
Is that right??
Is that double?
Greetings Ton
Hi Ton,
if you want to use two Red Baron DACīs parallel with the onboard I/V stage, you must connect it like this:
1st - Every DAC module needs all parts of the I/V stage, expect the I/V resistors. Adjust the DAC output to 0V (DC-offset of the TDA1541A).
Donīt forget to make the small modification and switch the source and drain of the MOSFET like in this picture !!!
2nd - The output of the current buffers on each DAC module (inner four-sided point of the I/V resistor) must be connected together (parallel).
3rd - You need only one pair of I/V resistors with 250R value on one DAC module (four-sided / round point).
4th - You connect the DC-Reference Module as followed:
From DAC module
Ref. (Audio out) --> Ref. +5V
GND (DC Digital) --> GND
From DC Ref. Module
GND Ref. Left --> GND RCA Left
GND Ref. Right --> GND RAC Right
You could see it on this photo
5th - Trimm the RCA GND to 0V
Thatīs it.
Cheers
Reference TDA1541A DAC project PCBīs / Tube-I-zator PCB
Stock status in my Blog
Old 11th October 2011, 12:37 AM   #785
noizas is offline noizas  Lithuania
Hi Oliver,
I cannot catch idea, how it is possible to adjust AOR and AOL outputs to 0 VDC (to GND/A) without I/V resistors?
If R1 and R2 are missing there are no pull up circuits with DC source "above" GND/A to compensate -2mA drain, IMHO.
Maybe I'm missed something, can you explain?
Saulius
Old 11th October 2011, 01:54 PM   #786
Originally Posted by noizas View Post
Hi Oliver,
Saulius
Hi Saulius,
all measurements must be done with the I/V resistors, correct.
Old 12th October 2011, 10:00 AM   #787
I have 1 red baron playing, with a sp/dif entree , made of the CS8414 chip.
The same (old) problem occours: BCK wont accept the 68R and 220R.
It dont need''s a buffer.
What is at this moment the best ( buy??) thing to do.
Anton
Old 12th October 2011, 10:05 AM   #788
Anton
What do you mean? If it plays without the attenuation resistors, i'd opt to just leaving them out. I tried using the buffer stage made by Oliver, but there is significant jitter introduced...
Old 12th October 2011, 10:37 AM   #789
Hi Studiostevus
I disconnect both resistor''s at the point where they meet with BCK, else
no sound, with Dac v2.3 te same.
anton
Old 12th October 2011, 11:18 AM   #790
May be due to the level of the bck signal. You can fix this by:
- connecting bck directly without the resistors
- using a buffer to increase the bck signal, and then the resistors to decrease them again. This doesnt have my preference
- Check ecdesign's thread on the latest circuit for i2s attenuation (using diodes) and devise a circuit that fits your bck-source
On the other hand, the cs84xx is a widely used receiver. Maybe someone who has used this one can reply on how to get it working
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 12:20 PM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 03:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 10:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 06:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 06:15 AM
