| Group Buys Members group buys |
| View Poll Results: Surface Finish for future PCB´s | |||
| ENIG - Electroless Nickle/Immersion Gold |
41 | 43.62% |
| Immersion Silver |
30 | 31.91% |
| Immersion Tin |
15 | 15.96% |
| OSP - Organic Solderability Preservatives |
8 | 8.51% |
| Voters: 94. You may not vote on this poll | |||
#741 |
Hi Oliver,
how is going on development of DAC module V3.0 ? I'm very interested in, because V2.3 is little bit too big for my project of balanced DAC (here are many of Salas shunts mounted already ).Best regards Saulius |
#742 |
Hi Saulius
the 1st V3.0 DAC is in the testing phase. I hope i am ready with all tests till end of September. ![]() Best regards, Oliver
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB / SSHV-Shunt PCB
Stock status in my Blog |
#743 |
I just built a lampizator output (similar to tubizator) as I had the parts lying around but never got around to building it. Comparing to the Pedja Rogic stage, my first impressions are:
- Tubes are more 'sweet' than the DDNF stage.. a bit more highs - Indeed the DDNF stage is more punchy - The bass of the tubes is quite boomy to my taste, there is not much detail in the bass - The DDNF stage has more definition (must admit that my DDNF stage is powered with Salas shunts, and the tube stage with a linear psu) I quite understand why you would like to switch between them, as both have their hightlights. Some music just sounds better with one stage than the other. |
#744 |
EC design's 1 output (2x sk170) in to a tube preamp is what i am using, i hope
that DAC V3.0 will bring out a good solution. |
#745 |
#746 |
I'm on 6n2p now
#747 |
Nice choice. Of course the coupling caps are a key part. I am running Obligato PIO 2u. Work well. Russian KBG are a step up. I bypassed them with .1u Russian Tefon, and the HF opened up a new window. Very cost effective.
I suspect the quality of R1 and R2 are equally important, but I have yet to test. I did add a cathod bypass cap to R1, and like the effect. just put a 150u 16v Oscon SEP on the resistor. It added more grunt and texture to the lower end. B+ power quality counts but not as much as cap choice. adding good transformer and a choke cleared away a little haze. |
#748 |
I am using
B+ = 190v Rk= 200ohm kiwame Riv= 50 ohm shinkoh Output caps = obbligato gold 2.2uf Should be fine, and it sounds fine. I just like the discrete stage a bit better overall (but on some music the tubes).
-------- TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling |
#749 |
Almost identical to my setup. I have Riv at 90 ohms. Lampizator claims its a bit more laid back at 50. I have not experimented so no idea.
#750 |
Hi Oliver,
I fired up my DAC for the first time last night, and everything seemed to work fairly well. I'm using a CD player with digital out as a transport. I'm using the Twisted Pear SPDIF converter through your high speed buffer. Today I turned it on, and I'm getting music out of the the left channel only. When I turned up the regulator supplying them to 5.5v I got sound out of both channels but it was very distorted. ![]() Any ideas? ![]() Ned |
| i2s bus vs. i2c bus | Doovieman | Digital Source | 9 | 5th February 2013 02:08 PM |
| My take to the "Reference" TDA1541A DAC with I2S-BUS architecture | dvb-projekt | Digital Line Level | 130 | 30th January 2011 01:54 PM |
| what is "ground bus"? | gychang | Parts | 4 | 12th November 2007 09:21 PM |
| PCM2707 I2S out to TDA1541A DAC | TV Man | Digital Source | 3 | 4th December 2004 05:53 PM |
| A real DAC Philips TDA1541A "Double Crown"? | dbhh | Digital Source | 17 | 7th May 2004 05:15 AM |
