Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 88 49.44%
Immersion Silver 49 27.53%
Immersion Tin 23 12.92%
OSP - Organic Solderability Preservatives 18 10.11%
Voters: 178. You may not vote on this poll
Old 14th April 2011, 05:18 PM   #601
studiostevus is offline studiostevus  Netherlands
Transformer problem solved... turned out my DMM was malfunctioning! What are the odds of that??
I actually got some sort of output now from the TDA using a 75ohm resistor to gnd yesterday, but it was horribly distorted. A sine wave from a test CD looked like a square signal, but something was moving.
I just tried again, and let it play for some minutes and after a while .......... a NICE CLEAN SIGNAL APPEARED !!!!
Victory at last! This weekend I will rig up an output stage, and then I will finally get this baby going!
Needless to say, I am pretty pleased with this!
Old 14th April 2011, 05:25 PM   #602
And while I am at it, I want to take this opportunity to thank Oliver for the Sunday morning session 2 weeks ago at his place. He mentioned it was his honour driving him, and he spent considerable time getting my dac boards going! So thanks to Oliver!!
It turned out that the problem in my boards were the small inductors on the board. These had (maybe through soldering, maybe through transport) stopped functioning. So this is one to check first if your board doesnt work, and avoid some sleepness nights
Old 14th April 2011, 05:33 PM   #603
Malka07 is offline Malka07  England
Hey StudioStevus,
Glad you found the problem and finally got it working
Looking forward to your views on it
Alon
Old 14th April 2011, 05:59 PM   #604
ernesternest is online now ernesternest  Europe
ernesternest's Avatar
Default Finally
Hi Studiostevus, yes really good to hear that your baby is on the way to be a perfect DAC. Congratulations!
Ernst
Old 15th April 2011, 03:59 AM   #605
noizas is offline noizas  Lithuania
Hi Studiostevus
it is nice to hear you have solved you issues succesfully
Because I still have my shunt regulator unsolved, it is interesting to know how you solved the transformer problem? Does high voltage input really influence on too high output or here was something else?
Now you will be happier and happier every day next week at least - I have experience that TDA1541 is going to "burn in". So be patient please...
For example my double crown was going onto it's real sound more than one month! I was playing mine Philips CD 960 at least few hours per day.
Best wishes for your weekend!
Will wait for review on your DAC.
Old 15th April 2011, 10:05 PM   #606
Originally Posted by noizas View Post
Hi Studiostevus
There was actually nothing wrong with the transformer. Just my DMM was very consistent in displaying 46% more voltage than it actually measured. Hence, I thought it was 17V while it was a nice 12V. For the same reason I turned down the shunts until the DMM read 6V and I couldnt get lower than that. In reality they were giving only 4V...
So with a new DMM I could turn up the shunts, fiddle around a bit more, and voila!
Old 17th April 2011, 07:03 AM   #607
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
To have a central place for all informations of my project,
you could look into my
Blog.
Here you find also the actual stock status of the specific modules.
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 17th April 2011, 12:50 PM   #608
crobbins5421 is offline crobbins5421  United States
Default Impressions on the DAC board mod...
The bypass mod on the DAC board is complete and I agree with the other posts that it made a positive difference in my system.
While the detail improved, the biggest change for me was the soundstage clarity (defined spaces for instruments and voices) and "analog smoothness". Unbelieveably good......
Old 19th April 2011, 10:19 AM   #609
antonioo is offline antonioo  Netherlands
Hello I a'm new to this forum.
I never thought i be still building DAC's at the age of 61.
I used D.D. spdiff and for USB i used from DAC's - www.pcm63.com - All For High Quality Audio DIY they have a USB
entry for just 15 dollar!!! both the entry's play without a buffer.
Sound is good, best i heard all my live!!
Old 20th April 2011, 01:11 PM   #610
Guys, good news.
We have lift-off!! I now also got my Pedja Rogic i/v stage going, and I finally (after 9 months) have music out of this thing.
... now happily burning in ...
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 11:20 AM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
