Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 85 48.57%
Immersion Silver 49 28.00%
Immersion Tin 23 13.14%
OSP - Organic Solderability Preservatives 18 10.29%
Voters: 175. You may not vote on this poll
Old 2nd March 2011, 12:23 AM   #511
acccruz is offline acccruz  Portugal
Hi Mr. Oliver:
I need some of your PCBs:
-Separate Shunt regulator module for additional parts (5v)
-Tubizator PCB V2
-Shunt regulator module for Tubizator
They are all available?
Thank you.
Old 2nd March 2011, 02:04 AM   #512
chchyong89 is offline chchyong89  Malaysia
Send a message via MSN to chchyong89
I can't view the photos uploaded at my country. They are showing a frozen frog. Are there any other way to view it?
Old 2nd March 2011, 06:09 AM   #513
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by acccruz View Post
Hi Mr. Oliver:
-Tubizator PCB V2
Thank you.
Yes. PM send.
Witch photos you cant see?
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 2nd March 2011, 06:39 AM   #514
all
btw,
+/- Power Supply Module: $23
TDA1541A shunt regulator Module: $20
Shunt regulator Module for add. +5V line: $10
TDA1541A DAC Module: $18
Professional 2-Layer PCB: $32
The last thing i need to get is the output from PCM2707/6 IIS right?
can you PM me ur paypal address and above charges inclusive shipping to malaysia?
Old 2nd March 2011, 09:14 AM   #515
btw,
Hmm, you could see all modules also in the Members Galery here on diyaudio.
If you want to build my complete DAC, you need:
2x +/- Power Supply Module: $46 (four voltages lines)
1x TDA1541A shunt regulator Module: $20
1x Shunt regulator Module for add. +5V line: $10
1x TDA1541A DAC Module: $18
1x Tube-I-zator V2.0 Module: $30
Because you want to use the PCM2707/6 (VDD=3.3V) as II2S converter you need also a buffer IC in between,
e.g. my Ultra High Speed Buffer Module ($10).
Worldwide shipping: $ 9
paypal fee: 3,9%
If you want to order, please send me a PM or a mail to diyaudiopcb (at) gmx.com with your paypal address.
Old 2nd March 2011, 04:13 PM   #516
Ups... the price is $11, not $10.
Old 2nd March 2011, 05:11 PM   #517
payment made
Old 2nd March 2011, 08:15 PM   #518
studiostevus is offline studiostevus  Netherlands
Hi Guys,
I am debugging my setup, as I have zero sound.
Setup:
-Doede Douma's SPDIF to I2S converter
-Single TDA board
-Home built output stage (discrete)
Likely suspect is the output stage, but I would like to rule out the rest first. Maybe you can help me:
-What voltages do you measure at the I2S input of the TDA board?
-What voltages/amps do you measure directly at the output of the TDA chip?
-How can I otherwise verify that everything up to the output stage works fine?
Thanks!
Old 2nd March 2011, 09:13 PM   #519
Malka07 is offline Malka07  England
Hi Studiostevus, have you got the buffer board connected between the spdif board and the dac board? If not then that might be the problem.
Alon
Old 2nd March 2011, 09:35 PM   #520
Alon
I am only using Doede's SPDIF board (not the USD2I2S board), so I should not need the buffer in between...
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 12:20 PM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 03:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 10:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 06:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 06:15 AM
