Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 88 49.44%
Immersion Silver 49 27.53%
Immersion Tin 23 12.92%
OSP - Organic Solderability Preservatives 18 10.11%
Voters: 178. You may not vote on this poll
Old 23rd November 2010, 01:56 PM   #331
Malka07 is offline Malka07  England
Originally Posted by dvb-projekt View Post
So you have set only the AIF/MS switch to the + position, the others to the - position, right?
No i have the others in the middle and the AIF/MS to the right. I will try with all others to the left...and AIF/MS to the right.
I have just tried it...and still nothing.
Old 23rd November 2010, 02:09 PM   #332
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
So lets measure the voltages direct at the TDAs.
Pin 28 should have +5V
Pin 26 should have -5V
Pin 15 should have -15V
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 23rd November 2010, 02:19 PM   #333
Oliver this is what im getting
Pin 28 = +4.90v
Pin 26 = -4.70v
Pin 15 = -14.85v
Old 23rd November 2010, 02:23 PM   #334
Thats in normal tolerance. Could you measure the data frequencies also at Pin 3 of the TDA?
Old 23rd November 2010, 02:26 PM   #335
Sure...do i need to be playing a signal?
With music playing...it varies from 0.02 to 0.03 Khz
Old 23rd November 2010, 02:42 PM   #336
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
Pin 28 = +4.90v
Pin 26 = -4.70v
Pin 15 = -14.85v
Those TL431s are pretty inaccurate, with no way to adjust them in this configuration.
But you are getting voltages on the chip, so that's a good start.
When I had this problem, I was getting +5v digital to the X2, but not to the reclocker, due to the coil being broken so please check for voltage on the 74HC02 chips too. Pin 14 should be +5v 1v. To find pin numbers, pin 1 is at the mark, or if no mark it is anticlockwise next to the indent or chip on the end. Then numbers count anticlockwise - so pin 14 is the last one you come to.
Lucas
Old 23rd November 2010, 02:55 PM   #337
That sounds like DMM flutter to me. In other words, that sounds like it could be no signal at all.
Lucas
Old 23rd November 2010, 02:56 PM   #338
When I had this problem, I was getting +5v digital to the X2, but not to the reclocker, due to the coil being broken so please check for voltage on the 74HC02 chips too. Pin 14 should be +5v 1v. To find pin numbers, pin 1 is at the mark, or if no mark it is anticlockwise next to the chip on the end. Then numbers count anticlockwise - so pin 14 is the last one you come to.
This are the Voltages im Getting Lucas.
All other Voltages are 0v
Old 23rd November 2010, 03:17 PM   #339
Alon,
when i am at home, i connect my Twisted Pear pcb in my circuit. Then we will see...
Old 23rd November 2010, 03:29 PM   #340
All voltages correct throughout then, measured at chips themselves. That 4.83v is pin 14, the VCC for that chip.
I see you have those tiny reclocker chips in place. Do you have any 74HC02 chips to throw in there, just in case? They're dirt cheap (30p each) and work well.
It does seem from what you've said that the data may not be reaching the TDA chip at all, indicating that the Twisted Pear is not set up properly, or the reclocker chip is not working.
Are your DAC boards v2.2 or v2.3. If v2.2, have you lifted the appropriate pins on the chips or removed the traces, as instructed by Oliver?
Lucas
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 11:20 AM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
