"Reference" TDA1541A DAC with I2S-BUS architecture
Surface Finish for future PCB´s
  • ENIG - Electroless Nickle/Immersion Gold
    Votes: 93 48.7%
  • Immersion Silver
    Votes: 54 28.3%
  • Immersion Tin
    Votes: 24 12.6%
  • OSP - Organic Solderability Preservatives
    Votes: 20 10.5%
  • Total voters
    191
Is there an up-to-date BOM for the project ?
Based on Oliver's original BOM, I wrote a little spreadsheet that works out what to order from whom. It's easy to change quantities and add or delete components as you go along.
The downside is that it also tells you what you have spent - or are about to spend.
If Oliver has no objections, I'm happy to forward it to anyone interested.
HTH
Joined 2009
HTH
Go ahead :up:
Here it is. There's nothing fancy and it should be easy to "localise".
Notes:
* You must fill in row 4 with the number of modules to be built.
* Items in a strike-out font are part of the original spec but had to be substituted. It made sense to keep them in the list but mark them.
* You need to put your suppliers in column I and edit J66 to J72 to match. If you add new rows for parts not on my list, you need to edit the range as well.
Usual disclaimers apply. Let me know if (when) you find errors.
  • TDA1541A Project - BoM.zip
Joined 2009
Notes:
Very cool spreadsheet! Only two changings on Salas recommendation:
  • Change the 220R resistors on the shunt´s to the Takman REX carbon type
  • Delete the 0,1µF bypass caps for all shunt´s
Merry Christmas!
Christmas holidays, always a good opportunity to do some diy. Unfortunately, since I am travelling to family abroad it will be limited to some 'paper research'... currently trying to figure out the functioning of the Pedja Rogic Diamond I/V stage.... not very far yet.... if someone knows good (dummy) literature on such discrete stages let me know...
Joined 2009
The Ultra High Speed Buffer PCB´s arrived!
That´s the "ready to use" module, witch will be shipped.
As i wrote before, you could use it on top to the
Twisted Pear "Opus WM8804 Receiver" Module.
I am just waiting to the 3-pol Wago Terminals that i´ve ordered.
After checking the module, i will collect the money for the pre orders.
:cheers:
Pre Orders:
Malka07 - 1x
studiostevus - 1x
Crusty - 1x
kamaths - 1x
av-trouvaille - 1x
ernesternest - 1x
noizas - 2x
