Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 85 48.57%
Immersion Silver 49 28.00%
Immersion Tin 23 13.14%
OSP - Organic Solderability Preservatives 18 10.29%
Voters: 175. You may not vote on this poll
Old 13th January 2018, 10:46 PM   #1581
aguaazul is online now aguaazul
Suffers from the DIY Audio Illness
aguaazul's Avatar
TIC,
Oliver sent me the schematic for the UHS Buffer.
Also the 74HC02 Schematic so you can make your own.
UHS Buffer - Google Photos
Old 14th January 2018, 02:22 AM   #1582
wlowes is offline wlowes  Canada
wlowes's Avatar
The key is... WaveIO outputs I2S, and Red Baron expects to receive I2S. So make the connection and you are in business. The options for connecting are with U.FL cables (preferred) or by unshielded wires. Toslink is a competing interface to I2S. BNC is a type of connector that would compete with U.FL.
Old 14th January 2018, 11:01 AM   #1583
Ryelands is offline Ryelands  United Kingdom
I have a couple of those 74HCO2 buffer boards that I bought way back when but never got round to using. :<(
I'll not be using them now - if anyone wants one, PM me. Yours for the price of the stamp.
Dave
PS: wlowes - good to see you around.
Old 31st January 2018, 09:50 AM   #1584
TIC37 is offline TIC37  Sweden
Default Building
I have started building the Red Baron and so far so good.
Rectification, Done!
Shunt board, Done!
Red Baron, done and the rest is ongoing (waiting for components).
I have on the shunt board -15.30 volts, -5.501 volts and +5.502 volts stable after 10-15 minutes. I had to change one of the heatsinks for the 15 volt rail cause it got really hot (toutchable for 3-5 sek) but it turned out that the sinks that I recieved in the package (bought from another earlier buyer) was only 40 mm high and luckely I had some 50 mm sinks laying around so now I am good.
Still missing the 3.3 volt line cause I am missing parts but I was wondering if there are substitutional part for the DX45H8 that was recommended in the rebuild of a 5 volt line?? I have problem locating this DX45H8 locally and was thinking that there must be substitutes?
I connected the Red Baron board for the first time last night and measured some voltages on the board to confirm function, I had, without the TDA chip installed and no load, on pins;
15 - 5.529 volt
16 - 5.527 volt
17 - -5.521 volt
26 - 15.28 volt
27 - 15.28 volt
28 - 15.29 volt
just wonder if someone can confirm the values here.
I also have a question about the DC Reference board, it says 470 uF caps but would it be possible to use 330 uF Nichicon Muse here (have them home and don't want to spend money if not needed)??
Finally, I am setting up a Salas Reflector D for 5 volt for the Twisted Pear WM8804 and Waveio boards, would it be sufficient with 4700 uF cap instead of 10000-22000uF that is recomended from Salas or is it tooooo small a cap??
Is there anyone who know what current draw I should expect from the WM8804?
Information from Cirrus Logic just state that the chip itself draw 2.6-3.7 mA but it doesn't say anything at TP site about total use??
Carpe Diem
Old 7th February 2018, 01:43 AM   #1585
kp93300 is offline kp93300  Malaysia
Need help regarding the Tube I zator board.
What and where to measure with the adjustment of the trimmer on the board?
Kp93300
Old 7th February 2018, 06:12 AM   #1586
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
&quot;Reference&quot; TDA1541A DAC with I2S-BUS architecture
Kp93300
Wrong thread... Anyway, all measure points are painted on the PCB and will be measured to GND.
Tube-I-zator Professional PCB
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
&quot;Reference&quot; TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 12:20 PM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 03:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 10:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 06:53 PM
A real DAC Philips TDA1541A &quot;Double Crown&quot;? dbhh Digital Source 17 7th May 2004 06:15 AM
