Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 88 49.16%
Immersion Silver 49 27.37%
Immersion Tin 23 12.85%
OSP - Organic Solderability Preservatives 19 10.61%
Voters: 179. You may not vote on this poll
Old 29th September 2017, 01:39 PM   #1571
kp93300 is offline kp93300  Malaysia
I have a fully populated red baron v5 board with the current buffer installed.
Recently completed a tube i zator board.
Can i take the current out off the board directly without removing the 2sk 216. ?
See attached picture.
Old 11th October 2017, 02:18 AM   #1572
KennethDK is offline KennethDK
Are there still available boards?
Looks like a killer dac stage to combine with a tube stage
Old 11th October 2017, 09:19 PM   #1573
fccn75 is offline fccn75  United States
Default upload pcb files?
I understand Dvb Projekt ended the Red Baron awhile now, but can the Red Baron V5 pcb file be posted via link so we can continue for those late in the game?
Old 15th October 2017, 09:02 PM   #1574
That would be awesome. Huge fan of tda1541
Old 7th November 2017, 04:35 AM   #1575
noizas is offline noizas  Lithuania
Hi
I still have some different versions of bare Red baron unneeded.
How many do you need?
Please PM me.
Saulius
Old 7th November 2017, 07:10 AM   #1576
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
To be save, remove the 2SK216.
Unfortunately my RB V5.0 files are blown away at a HD crash.
Best regards,
Oliver
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 14th December 2017, 08:58 PM   #1577
TIC37 is offline TIC37  Sweden
Best regards,
Oliver
It's really pity but I have at least got my hands on a Red Baron DAC that I am about to start building but I have a question about the SK170. I saw that Salas have changed the fets for SK117 in his SSHV shunt, is it possible to go the same way for the Red Baron or is it mandatory with SK170??
The price is major reason for asking but since Salas have changed the use of SK170 to SK117 I don't see no reason that it should not be possible doing the same here.
Carpe Diem
Old 11th January 2018, 09:45 AM   #1578
Default Ordered
Ok, I ended up ordering the SK170BL anyway....
Since I am up to this project now and I realize that some information is gone bye bye I will have to ask questions and I hope someone out there is prepared to answer.
First question is about the High speed buffer, I have the Twisted Pear Opus WM8804 and will have to fix the High speed and if I can not get it via Oliver is it difficult to do it myself on a breadboard?? I will need some kind of schematics cause I am not the one who do (no electronical engineer), I repeat (the monkey with soldering iron) what others have come up with.
Second question, I understand that the DAC is needed for the signal but since I am not that experienced with the general build up of the signal path in a DAC I wonder what is needed to get the signal to the DAC board and then to the Output stage??
Carpe Diem
Old 12th January 2018, 12:06 AM   #1579
Questions are more or less cleared so I only have one little question to be answered before building the Red Baron; I understand that incoming signal can be of different kind but if a want to use incoming RCA signals, are they.... I2S or??
BNC is....??
and finally Toslink is.....??
Will all these mentioned connectors be connectable to, or via WavIo because that is what I intend to use as main input for the signal? I need help understanding this so please bare with me.
Carpe Diem
Old 12th January 2018, 04:40 AM   #1580
BNC is....??
RCA, BNC or Toslink are S/PDIF signals. If you want to use this connections, you must have a S/PDIF to I2S converter.
The WaveIO converts USB to I2S. I hope that help
Best,
Oliver
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 11:20 AM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
