Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 85 48.57%
Immersion Silver 49 28.00%
Immersion Tin 23 13.14%
OSP - Organic Solderability Preservatives 18 10.29%
Voters: 175. You may not vote on this poll
Old 13th August 2014, 06:43 AM   #1251
alfred wan is offline alfred wan  Malaysia
Hi ,
I am interested too on this. In fact I bought your I tube Zator 2 years ago when I was in Nz, populated and waiting for a dac to mount it. I always remember you are a helpful guy. I can see the RB is damn good and sexy, great one!
A fast few Question, I want the 1541ax1 runs passive,nos, simple psu. Do I still need the shunt board and psu board? Sorry I am not good in digital stuff.
PM me please... tq.
Old 13th August 2014, 07:53 AM   #1252
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by alfred wan View Post
Hi ,
PM me please... tq.
Hi Alfred,
you have a PM!
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 4th September 2014, 01:43 AM   #1253
duderduderini is offline duderduderini  Australia
Default Are these boards still for sale?
Hi there
Does anyone know if the red baron and tubeizator are still for sale?
I want to set up an sd card reader that outputs I2S into the red baron and then a tube output.
What boards will I need?
The other option is to have a seperate dac like the buffalo so I can decode higher res files I make from recording my vinyl. I use an maudio card to record 24 bit 96kHz for vinyl so I figure i will need 1. SD card reader 2. dac with i2s (one being tda 1541A for cd resolution and another for hi res) then the tube output stage.
"Better to say nothing and keep them guessing than to speak and remove all doubt."
Old 4th September 2014, 06:26 AM   #1254
Originally Posted by duderduderini View Post
Hi there
the Red Baron and the Tube-I-zator are in stock.
For the Tube-I-zator you will need only a transformer, because the PSU for HV and Heater is on board.
The Red Baron needs four regulated input voltages (-15V, -5V, +5V and +3.3V).
Best regards,
Oliver
Old 4th September 2014, 11:09 AM   #1255
Default Hi Oliver
Thank you for your reply.
Could you pm me prices for boards including shipping to Australia. I was thinking about 2 sets of boards.Do you sell the regulated dc boards as well?
regards
Nick
Old 13th September 2014, 04:34 PM   #1256
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
Originally Posted by andrea_mori View Post
Hi all,
if anyone was interested in the custom Laptech crystal
http://www.diyaudio.com/forums/group...up-buy-70.html
please add your name in the wish list at
http://www.diyaudio.com/forums/digit...ac-kit-96.html
The minimum orderable quantity from Laptech is 5 pcs for each frequency.
When that quantity will be reached I ask Laptech for a quote.
Andrea
As promised, the list of interest is started.
http://www.diyaudio.com/forums/digit...ml#post4057057
Old 13th September 2014, 09:22 PM   #1257
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
Hi Oliver,
Long time! My DAC is mothballed at the moment....the old Teradak USB to i2s converter is dead, it seems (It never worked reliably for me anyway). I know that people here have moved on from that device. What are the best options these days for various inputs please?
Many thanks
Lucas
Lucas
Old 19th September 2014, 09:46 AM   #1258
dtses is offline dtses
Originally Posted by dtses View Post
wlowes
could you please comment on the layout below?
- There are 9 Salas shunts in total, some of them will still have a bit long connection from both sides.
- Ian's PCM board will be placed on top of DAC board
- Will use ipx mini coax cables to connect spdif module to PCM board
- PCM and DAC boards will be hard soldered, 2-3cm cables will go directly to TDA chip.
So I made the updates and burned one reg on PCM board accidentally! Anyway it's fixed now!
Sorry, no pics, will provide later.
A question most likely to Oliver
As a result of my update, I do not get any sound from the TDA chip now (w/o DDNF board). It is set to simultaneous mode as it should for PCM daughter board. All connections are triple checked and are the same as before I added mini coax cables and the DAC was working. The schematics is triple checked as well and is equal to v5.0.
When scope is connected, all 4 outputs (Data L, Data R, BCK, LE) have proper signals. Ian has confirmed that PCM board should be fine, but the output from TDA is completely silent. The only thing that could be is the DAC board I assume.
Unfortunately the worst thing here is that I'm stuck with this issues already for a month Would very appreciate any help!
Old 19th September 2014, 10:20 AM   #1259
PixelPlay is offline PixelPlay  Australia
Default My Red Baron 5 is also still not working
Well I still have the problem stated further back. No sound either. I'm not using Ian's boards however I have tried the version 5 boards with waveio, aminero, exa with no sound at all. Changed tda1541a chips 3 times, used various output stages, changed caps on the dac chip. Still silence, I do get garbled noise if I change the jumper next to the chip to simultaneously mode.
Really frustrated as I have checked all components numerous times.
Anyone able to help?
"Live each day as if it is your last"
Old 19th September 2014, 12:24 PM   #1260
that's weird as I did manage to get the DAC working with Amanero (i2s) fine and later with Ian's PCM daughter board.
Then I made the above upgrades and vuala - no sound at all...
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 12:20 PM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 03:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 10:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 06:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 06:15 AM
