Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBīs
ENIG - Electroless Nickle/Immersion Gold 88 49.44%
Immersion Silver 49 27.53%
Immersion Tin 23 12.92%
OSP - Organic Solderability Preservatives 18 10.11%
Voters: 178. You may not vote on this poll
Old 19th September 2013, 06:36 AM   #1131
noizas is offline noizas  Lithuania
Originally Posted by jcastellano View Post
The Metronome is config as 48khz as I do not know for sure the limits of the RED BARON in terms of sampling rate and bit depth. I will try 96khz soon and will report back.
Jorge
Hi Jorge
Red Baron is limited by TDA1541.
It is 16 bit resolution, maximum 200kHz sampling rate in all modes (simultaneous or time multiplexed) by it's datasheet.
However Ian has tested it in simultaneous mode at 352,8kHz with his "Universal I2S-PCM driver board" (look into thread "Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board").
So you should be successful at 96kHz/16 bit in I2S mode.
Saulius
Old 19th September 2013, 11:35 PM   #1132
Wargreymon is offline Wargreymon  Spain
Another doubt I have is: Does the Red Baron Dac support 24 bits 96 KHz.? I made the error not check the config of the Musiland and it was set at 24/96... But if the receiver locks with the signal, it is wonderful....
More to come....
Jorge
It can not support 24 bits because the TDA1541A is a 16 bit chip. No problems with the sampling rate though, it can be has high as 352.8 KHz (Not sure if this is only when using simultaneous mode), the fs equivalent to 8x Oversampling. The problems I found with increasing sampling frequency is that THD also goes up when using 96KHz and up, probably caused by the lack of filter in the output. I only tested this with the ARTA, have not listened to music with such high sampling rates, so I can not say anything about that.
Old 20th September 2013, 12:29 PM   #1133
dtses is offline dtses
any comments from Oliver would be very appreciated on how to connect TPA and RB dac and eliminate that hissing sound?
Old 20th September 2013, 06:47 PM   #1134
mrsavage is offline mrsavage  United States
mrsavage's Avatar
Default How do you buy these PCB's?
I would like to obtain some of these PCB's. The power supply boards can be used
on other projects. The same is true for the regular PCB's. Let me know how and where to buy some of these great PCB's.
Old 20th September 2013, 09:12 PM   #1135
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Hi dtses,
with the Red Baron V3.0 & V4.0 (without modifications) you need the UHS-Buffer in between.
If you did make the 3.3V I2S mod., i would say that you could omit the UHS-Bufer module. Unfortunately i couldīt test this, because i had sold my TPA.
Reference TDA1541A DAC project PCBīs / Tube-I-zator PCB
Stock status in my Blog
Old 20th September 2013, 09:13 PM   #1136
Hi mrsavage,
if you would like to order something, i need a PM with your paypal address for the invoice.
Best,
Oliver
Old 21st September 2013, 08:43 AM   #1137
hi Oliver,
yes, the i2s mod is done.
Could you please give any hint about the board or some further tests? Do I have a correct signal on BCK output?
Old 28th September 2013, 10:53 PM   #1138
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
some photos...
not sure how I'm going to lay it out, or use the hammond case or use the Amanero.
Old 8th October 2013, 02:51 PM   #1139
So, even though I bought a matched set of transistors for the shunt regulators they aren't needed?
I'm going to pop them in now.
Old 9th October 2013, 07:19 AM   #1140
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by noizas View Post
Hi Jorge
Saulius
TDA1541A sheet:
The high maximum input bit-rate and fast setting facilitates application in 8 x oversampling systems (44.1 kHz to 352.8 kHz or 48 kHz to 384 kHz) with the associated simple analog filtering function (low order, linear phase
filter).
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 11:20 AM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
