"Reference" TDA1541A DAC with I2S-BUS architecture - Page 11 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 80 47.62%
Immersion Silver 49 29.17%
Immersion Tin 22 13.10%
OSP - Organic Solderability Preservatives 17 10.12%
Voters: 168. You may not vote on this poll
Old 26th September 2010, 08:48 AM   #101
dvb projekt's Avatar
In my system i dont use the bypass caps, because my Fairchild Stealth Diodes have a extreme soft recovery and dont produce much HF noise.
Also we have the shunt regs. in the lines.
I think you should try it by yourself in your system with and without the 0,1F caps.
Perhaps you could post your experiences.
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 26th September 2010, 12:32 PM   #102
Yes I will. Since I'm using DSEP-12A I guess it can be omitted.
Old 26th September 2010, 01:01 PM   #103
LucasAdamson's Avatar
Oliver,
Could you explain the use of TL431ACLP for me please. I see that the Salas reg boards you sell, are described as "pre" shunt regulators, implying that the real regulation goes on at the TLA1541A board, and the TL431ACLP suggests this too, but I don't understand it.
Could you clarify for me please, especially as I am hoping to use Hypnotise Blue Edition boards for this build, and I want to get it right.
Many thanks
Lucas
Lucas
Old 26th September 2010, 03:26 PM   #104
Hi Lucas,
the TL431 for each powerline on the TDA1541A DAC module are a recommendation from Thorsten Loesch
in the development of the complete project.
If you only use one DAC module you can also try to skip the onboard regs
and connect the salas shunts direct to the output pin of the TL431.
Old 26th September 2010, 05:22 PM   #105
OK, so for a single non-paralleled DAC, I should probably skip them and get lower jitter. Then if I decide to add another chip, I can introduce some TL431s.
I'm not entirely convinced of the idea of paralleling chips, even though some of the top CD players have done this, and Thorsten seems to be unconvinced too. Lukas of Lampizator is a fan though, so who knows? I'll try a single chip - it's certainly cheaper!
Lucas
Old 26th September 2010, 06:56 PM   #106
The statement from Thorsten about the jitter counts to the I2S input with or without buffer ICs, not to the power lines
Old 26th September 2010, 08:49 PM   #107
Sorry, I was referring to what Salas said at the foot of the page about the comparison between the Salas and the TL431.
I erroneously used the word "jitter" in place of "noise" as I was distracted by the noise of my 4 year old hassling me at the time.
When it comes to shunt regs, I do trust Salas' advice as he has devoted such a considerable amount of effort on developing them, and they are highly celebrated, so I think I will skip the TL431, and any associated shunt-reg parts after the Salas. With a bank of smoothing caps the Salas alone should be superior to any supply in any commercial TDA1541A CD player, no?
Lucas
Old 27th September 2010, 06:09 AM   #108
Absolutely, yes !
Old 27th September 2010, 09:30 AM   #109
Do you know how many mA the single TDA1541A board pulls, as I need to add at least 100mA or preferably a bit more to keep the mosfets usefully occupied.
Lucas
Old 27th September 2010, 09:42 AM   #110
I would recommed to set the 3 shunt lines with a 10R to ~200mA each.
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 12:20 PM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 03:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 10:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 06:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 06:15 AM
Copyright 1999-2017 diyAudio
