Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBs
ENIG - Electroless Nickle/Immersion Gold 83 48.26%
Immersion Silver 49 28.49%
Immersion Tin 23 13.37%
OSP - Organic Solderability Preservatives 17 9.88%
Voters: 172. You may not vote on this poll
Old 8th July 2013, 01:38 PM   #1031
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
ok, great. Thanks for the reasoning.
Old 9th July 2013, 01:28 PM   #1032
Almost done with my PSU. Just need to order some more caps.
I haven't touched the high voltage 150+ v for the tube stage. What have you done with your high voltage section? I'd like to figure out what I need for this and maybe stick it in with the low voltage stuff.
If I can get a hold of your drawings for the case that would be great too.
Old 10th July 2013, 02:50 AM   #1033
wlowes is offline wlowes  Canada
wlowes's Avatar
Originally Posted by Ryelands View Post
Best DIY USB cable I've come across so far uses 30AWG Kynar wire-wrap wire - sonically as good IMHO as Cat5 solid core but, being flexible, less likely to damage connectors.
"Reference" TDA1541A DAC with I2S-BUS architecture-usb3-jpg
See pic - note that one of the pairs is D+/D-, the other is a doubled-up Gnd lead; there's no need for V+ with the WaveIO. (I didn't bother with a screen as the lead is so short. That, of course, minimises capacitance but I did it that way because, essentially, I'm lazy.)
Nice!
Where did you get the connectors?
If possible, even shorter is even better.
Old 10th July 2013, 04:50 AM   #1034
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Because i use a SSHV per channel and a tube rectifier for the B+, you dont see a populated HV section on my photos
Witch drawings did you like to have?
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 10th July 2013, 01:10 PM   #1035
I'd like to get your case diagrams. Hopefully everything will fit... and how you wired that connector up (that would be handy).
I might just be using an unregulated PSU for my tube stage.
Old 10th July 2013, 01:12 PM   #1036
Originally Posted by wlowes View Post
Nice!
Ebay!
Old 11th July 2013, 01:34 PM   #1037
I got a nice 17" x 11" hammond walnut case. Not sure if I should use it for the dac or the PSU.
How big is that case for your power supply?
Old 19th July 2013, 03:26 PM   #1038
Got the rest of my parts for the red baron from mouser today.
Old 2nd August 2013, 02:03 PM   #1039
Krokotam_ is offline Krokotam_  Bulgaria
Hello Oliver ,
maybe is something stupid i can`t figure at the moment but i need your help
I have connected all wires but nothing came , as far as I can touch every voltage is OK . Kind of wired but even 5 V is around 4,53 V .
http://postimg.org/image/7e8w28933/
My first suggestions are i/v outputs because i really hate to deal with them , can you please specify how to check output voltage ?
Another thing it seems that AOL and AOR differ ? one is 0.55 V other is around -7 v ?
http://ipetkow.olx.bg/ - Електронни компоненти .
Old 2nd August 2013, 03:25 PM   #1040
Originally Posted by Krokotam_ View Post
Hello Oliver ,
View image: dac2
atm i am in holiday, so it's a bit complicated to say.
Did you do the MOS-Fet mod. for the V3.0?
Best,
Oliver
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 11:20 AM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
Copyright ©1999-2017 diyAudio
