Group Buys Members group buys
"Reference" TDA1541A DAC with I2S-BUS architecture
View Poll Results: Surface Finish for future PCBīs
ENIG - Electroless Nickle/Immersion Gold 88 49.44%
Immersion Silver 49 27.53%
Immersion Tin 23 12.92%
OSP - Organic Solderability Preservatives 18 10.11%
Voters: 178. You may not vote on this poll
Old 24th June 2013, 12:36 AM   #1011
neda is offline neda  United States
neda's Avatar
Originally Posted by dvb projekt View Post
Hi Ned,
definitely the V5.0 with U.FL connection.
I donīt know if itīs the new layout, the U.FL connectors, the new Pin 4 to AGND connection with the new jumper or all together, but the sound is much more 3 dimensional and instruments are so realistic….
…and this with I2S input! What sound may we expect in simultaneous mode with Ianīs pcm board….
Letīs see…
Oliver
Hi Oliver,
I'm not very familiar with Ian's pcm board or operating in simultaneous mode, is that something that can be easily integrated into your design,
or does it require a total overhaul of the unit with all of Ian's boards?
Please keep us informed with plenty of photo's and sketches as your unit evolves.
You know what they say, "A picture is worth a thousand words".
Ned
Old 25th June 2013, 04:56 AM   #1012
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by neda View Post
Hi Oliver,
Ned
Hi Ned,
you could connect Ianīs PCM board easily in front of the Red Baron V5.0. It has a normal I2S input. The two jumpers on the RB must go to simultaneous mode. Thatīs all.
Ian will do some test with the RB V5.0 shortly and post his results here.
Oliver
Reference TDA1541A DAC project PCBīs / Tube-I-zator PCB
Stock status in my Blog
Old 25th June 2013, 11:52 AM   #1013
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
So, Ian's fifo board is a good fit with the red baron?
Old 25th June 2013, 03:45 PM   #1014
Definitely yes!!!
Old 25th June 2013, 03:58 PM   #1015
Lot's of options on IAN's board - it's got me puzzled.
Old 30th June 2013, 02:59 AM   #1016
wlowes is offline wlowes  Canada
wlowes's Avatar
Default Red Baron and S2
I am a happy camper. After searching for close to a year, a fellow Canadian provided me with an S2 double crown. Now very motivated to rebuild my TAD1541A DAC with proper case, Oliver's Red Baron and great power supplies. Currently enjoying standard tda with burson regs, lampizator output and Grundig DEM all driven by WaveIO.
The sound currently so good I was having trouble getting motivated to rebuild without birds nest wiring and many prototype reworks. Now with Oliver's very nice board and the S2 and S1 beckoning it is time get going. As always this will take a while. Look forward to digging deeper into this audio classic.
My plan is to build the ALIX processor and WaveIO into the DAC box to ensure shortest possible USB, I2S and power lines. Probably some 3D layout. Also inspired by Lampizator layout with inverted tubes and one box layout with isolation of areas. Thanks Oliver for providing a very nicely laid out PCB to host the TDA.
I'll let the source of this part speak up or stay silent. He has quite an inventory of TDA1541A chips.
Old 2nd July 2013, 02:04 PM   #1017
Hey, I picked up a couple of tda1541 chips too.
Which tubes are in your lampizator output stage?
I've got an amanero, and like the waveio I think it might be a bit overkill for the 16 bit tda1541 chip. I'm not sure what I'm going to do with the usb to i2s input yet.
I'm also looking into that fifo buffer for red baron.
Old 2nd July 2013, 02:42 PM   #1018
Ryelands is offline Ryelands  United Kingdom
. . . the waveio . . . might be a bit overkill for the 16 bit tda1541 chip.
The WaveIO works superbly with the TDA1541A, esp with a good PSU. Highly recommended.
Old 2nd July 2013, 02:46 PM   #1019
I am using a pair of NOS Tesla E83CC Gold Pin (1:1 to Telefunken ECC803S).
Old 2nd July 2013, 02:49 PM   #1020
Anyone use the amanero with the red baron?
"Reference" TDA1541A DAC with I2S-BUS architectureHide this!Advertise here!
My take to the "Reference" TDA1541A DAC with I2S-BUS architecture dvb projekt Digital Line Level 131 4th May 2016 11:20 AM
i2s bus vs. i2c bus Doovieman Digital Source 9 5th February 2013 02:08 PM
what is "ground bus"? gychang Parts 4 12th November 2007 09:21 PM
PCM2707 I2S out to TDA1541A DAC TV Man Digital Source 3 4th December 2004 05:53 PM
A real DAC Philips TDA1541A "Double Crown"? dbhh Digital Source 17 7th May 2004 05:15 AM
