Group Buys Members group buys
Waveguides and horns
Old 28th November 2011, 06:46 PM   #861
jzagaja is offline jzagaja  Poland
You need gently knock out with a broomstick and remove glue residue by wetting in acetone an hour or so. I'll ask Autotech for samples.
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 28th November 2011, 07:41 PM   #862
noah katz is offline noah katz  United States
Tome the top octave looks noticeably smoother with the stock phase plug.
Originally Posted by jzagaja View Post
... see below graph normalized to flat power. Better repeat on SEOS and baffle.
I find it hard to judge the directivity performance of anything other than a spectrogram normalized to flat on-axis response.
I'm not sure why, but I also find the stepped shaded graphs harder to digest than the previous smooth shaded ones.
Thanks for all your effort, jzagaja.
Noah
Old 28th November 2011, 08:29 PM   #863
ARTA directivity sonogram.
Old 29th November 2011, 05:02 AM   #864
_Wim_ is offline _Wim_  Belgium
Could you post the raw impulse data also? Then we can generate any view we want for comparison... Many thanks
Old 29th November 2011, 07:59 AM   #865
Enclosed. For samples please contact Autotech: info at autotech.pl
Old 30th November 2011, 08:33 PM   #866
guglielmope is offline guglielmope  Italy
Hello,
B&C phase plug look the same of that mounted on my Radian 475 PB as you can see in the picture.
Do you think that I can try your phase plug also on that driver without any problem?
Ciao
Guglielmo
Old 30th November 2011, 08:55 PM   #867
Internal dimensions are unknown. Remove and measure.
Old 1st December 2011, 07:08 PM   #868
Hello jzagaja,
I get some strange results looking at the raw data. I had to convert your files to pcm-format with Audacity before Arta could read them. But there seems to be something strange with level, as the higher of axis measurement are louder than the on-axis measurements. Did you make the measurements with Arta, of did you use some other software?
Old 1st December 2011, 07:27 PM   #869
ARTA files enclosed.
Old 2nd December 2011, 04:28 AM   #870
hum4god is offline hum4god  United States
hum4god's Avatar
Default iwata and B7C DCM50 ?
Hi jzagaja
did you ever get a chance to listen and measure the B&C DCM50 with one of your horns?
i would be especially interested how it sounds and measures w/ the Iwata 300 ?
thanks
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
