Group Buys Members group buys
Waveguides and horns
Old 10th November 2011, 07:39 PM   #831
noah katz is offline noah katz  United States
Originally Posted by jzagaja View Post
I'm checking possibility on BC DE250.
That would be great; there should be a lot of demand from the many I expect who will be using the DE250 on all the SEOS WG's soon to be available.
Will this be a simple retrofit?
Noah
Old 10th November 2011, 09:38 PM   #832
Defo is offline Defo  Norway
Is the E-JMLC in the picture below really 92 cm wide? Sure doesn't look like it considering the iwata one is 59
Old 11th November 2011, 08:00 AM   #833
jzagaja is offline jzagaja  Poland
Yes they are 92cm wide and doesn't destroy space around. I have them in my living room, impressive looking horns.
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 11th November 2011, 11:43 AM   #834
_Wim_ is offline _Wim_  Belgium
Originally Posted by rajacat View Post
Some complain that it's little shy of detail and high freq. extension. It would be great if your design would help in those areas.
Look at the measurement I have taken of my DE250 combined with an OS12 waveguide + foam plug from Geddes.
I does not lack any high frequency extension. I think people often mistake high frequency resonances for "detail", and if they here a system without, they say it lacks "detail"...
The measurement is taken with a 10ohm resistor in parallel with a 1µF capacitor to correct the roll off from the waveguide. No other equalizing is applied in this measurement.
For listening, I use a DCX2496 to correct the bumps at 2.2kHz,4.4kHz and 16kHz, the roll off correction is done passively with the 10ohm/1µF to avoid big boosts in the DCX.
Off coarse the correction of the bumps could also be done passively with 3 notch filters, but since I have an active system, it was easier in the DCX...
Overall I think this combination sound very good, but I am also interested in the phase plug to see what the effect is.
Old 11th November 2011, 04:19 PM   #835
BC DE250 compared to previous. It seems when phase plug curvature is much different (radius is larger) than of diaphragm then HF rolloff is higher. Polars are made of using 30 frequencies.
Old 11th November 2011, 05:03 PM   #836
Sonograms: 18sound vs. DE250
SPL 20deg: BMS 4550 vs. DE250
SEOS-15 with BMS 4550
Old 13th November 2011, 06:08 PM   #837
Let's do 5-slit plug for DE250.
Old 13th November 2011, 07:44 PM   #838
gedlee is offline gedlee  United States
gedlee's Avatar
Ouch!! That's a disater waiting to happen. You need to rethink that plug! The long channels with no flare is not a good idea.
What you need to look at is the DE500. Not my preference from a materials standpoint, but its short throat would lend itself very well to this modified phase plug.
Earl Geddes Gedlee Website
Old 13th November 2011, 07:56 PM   #839
Problem with ferrite drivers is long path (with low flare rate) from diaphragm to the exit aperture. I have to choices:
1) Remove some material like I did before so that phasing plug flare rate is slower.
2) Leave as is - see below
Old 13th November 2011, 08:06 PM   #840
gedlee's Avatar
Well neither is ideal and this is where "development" comes into play. You need to build them and test them and find out what the pros and cons are. The DE250 just may not be a good choice.
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
