Group Buys Members group buys
Waveguides and horns
Old 30th October 2011, 06:08 AM   #821
_Wim_ is offline _Wim_  Belgium
Originally Posted by paulspencer View Post
CAD drawing of DE250 based on measuring them with the calipers. It was hard to measure the exit tube, so that is the least accurate part - a shame because it is also the most useful part!
Many thanks. I was indeed also looking for the exit shape, but you drawing if already much better then what I could do myself...
Old 30th October 2011, 11:25 AM   #822
jzagaja is offline jzagaja  Poland
First comparison - 12" OS waveguide without baffle, original driver and membrane with strong breakup (titanium), "faulty" Fresnel phase plug with low compression. Simulation - ideal flat diaphragm and wavefront.
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 30th October 2011, 02:01 PM   #823
Same with 18sound NSD1095N diaphragm.
Old 8th November 2011, 07:13 PM   #824
4-slit Fresnel phase plug with conventional Ti diaphragm.
Old 8th November 2011, 08:17 PM   #825
gedlee is offline gedlee  United States
gedlee's Avatar
Jacik
I fear that you might be missing something critical in this analysis. You will not see any effect of the phase plug until you have a waveguide that shows little to no internal reflections and diffraction. In other words, the phase plug is not a limiting factor until the waveguide approaches almost ideal characteristics. The waveguide used here is not very "clean" and it will obscure what you are looking for.
I think that I have made this point on several occasions in the past.
Earl Geddes Gedlee Website
Old 8th November 2011, 08:24 PM   #826
Like I said it's for fun :-) Waveguide is without baffle and radius at mouth is ca. 2".
Old 9th November 2011, 07:08 PM   #827
Same with NSD1095N. Please note that 18sound uses deeper dome profile.
Old 10th November 2011, 04:56 PM   #828
rajacat is offline rajacat  United States
Good work! Looks like there's a smoother response with a little better directivity, if I'm reading the graph properly. Going into production soon?
Old 10th November 2011, 05:45 PM   #829
I'm checking possibility on BC DE250.
Old 10th November 2011, 06:02 PM   #830
I've never heard the BC DE250 but I gather that most find it competent and very smooth. Some complain that it's little shy of detail and high freq. extension. It would be great if your design would help in those areas.
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
