Waveguides and horns - Page 79 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 8th October 2011, 10:17 PM   #781
jzagaja is online now jzagaja  Poland
Send a message via Skype™ to jzagaja
Ok. let's go with the driver...
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 9th October 2011, 05:22 AM   #782
3GGG is offline 3GGG  Australia
Can anyone comment on how the Fane 8m will go with a JMMLC200 with a 125mm opening?
I will use a 3lt (approx) rear chamber for the driver.
My Le Cleac'h horn build
Old 9th October 2011, 08:50 PM   #783
Send a message via ICQ to cka3o4nuk
Hello dear comunity
just interested from what distance aceptible to listen e-jmlc horns
Horns
Horns
now i building Yuichi Arai A-290
Old 16th October 2011, 03:40 PM   #784
Spun aluminum domes - first trial. Plate thickness is 0.1mm, corrugations and cracks appears quickly.
Old 16th October 2011, 07:46 PM   #785
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Spun aluminum domes.
Use less tool pressure & make more passes to arrive at the finished profile. As the profile develops, change to a larger live center pressure pad (reverse profile) to better distribute the torsional forces.
Old 20th October 2011, 04:29 PM   #786
MikeR is offline MikeR  United States
Sounds like advice from a guy that has spun a little aluminum over the years!
Old 20th October 2011, 05:04 PM   #787
Better use a roller? Smoother surface, more uniform thickness, higher tensile strength. Below Ti diaphragm with TiN coating for benchmark.
Old 20th October 2011, 08:28 PM   #788
I expect results are very sensitive to alloy and temper - did you use one recommended for that process?
Noah
Old 20th October 2011, 09:29 PM   #789
7up aluminum can (side) that why it doesn't want flow again - was deeply drawn and oriented.
Old 20th October 2011, 11:06 PM   #790
Ah
Now if you could find out what's a suitable type for deep drawing, or try annealing the can material.
Or try cutting the material from the bottom, as it's closer to the final shape.
Noah
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 06:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 04:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 01:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 08:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 02:38 AM
Copyright ©1999-2017 diyAudio
