| Group Buys Members group buys |
#771 |
That's true. Set mesh size manually and now difference is small. Of course flux in gap is not homogeneous. BC DE250 cross section shows more elegant design. Do you know how large are real looses with non armco iron? FEMM seems to overestimate carbon steel.
Visit us at http://www.horns.pl/ The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here |
#772 |
Only the manufacturer is going to know that, if even they know it. Its not easy to get and very few companies would supply it. And if they are Chinese you can bet that its what they "hope" it will be not what it actually is.
Are you sure that all the longer the coil is, plus its excursion? That looks very small and a huge waste of the flux field. Terrible design if thats true. |
#773 |
Wait a sec... jzagaja, are you:
1) Designing your own compression driver 2) Designing a retrofit-able phase plug 3) Doing this for fun?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#774 |
At this stage it is for fun meaning making my own diaphragms, phase plugs. I took D800Ti driver as parts (it is available for everyone) prior magnetizing. STX is now making it's own coils using Tokoku CCAW.
#775 |
Hello Jack,
I think you have a lot of work to do in order to improve the linearity of the flux inside the gap. For comparison here is a project I used to study several years ago. Best regards Jean-Michel Le Cléac'h |
#776 |
Do you know real driver with such a smooth magnetic circuit? It seems for fast flare phase plug better use (now expensive) neodymium magnets (example JBL 476Be). Magnetizer is limited to outer diameter 250mm so for bass driver pole pieces must be mounted outside.
#777 |
Sorry to change the subject but does Erich or anyone know anything about the group buy shipment? Last I heard, we were hoping for a productive September. Thanks. Fingers crossed.
#778 |
One pellet is ready for shipping as far as I know.
#779 |
...truth seeker...
How does the SEOS-RAAL fit up with the RAAL 140-15D?
. Does the INOX front plate get covered in any way? Particularly any of the the sawtooth edge? . What benefits or changes to the response are there from using the waveguide?
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#780 |
SEOS-RAAL mounting copies RAAL 140-15D frontplate. Throat covers sawtooth (design width 27mm). We don't have this driver so I can't show any measurements.
| smith horns and using compression horns for a Karlson party speaker project | bikehorn | Multi-Way | 14 | 30th January 2013 05:20 PM |
| Horns inside of horns open foe discussion | oilcanracer | Multi-Way | 3 | 15th February 2010 03:42 AM |
| Compression drivers in horns or waveguides | 454Casull | Multi-Way | 6 | 1st December 2008 12:41 PM |
| Phase plug necessity in horns/waveguides | 454Casull | Multi-Way | 3 | 18th September 2005 07:36 PM |
| Horns: Vibrations and resonances in metal horns | Rocky | Multi-Way | 10 | 28th July 2004 01:38 AM |
