Group Buys Members group buys
Waveguides and horns
Old 14th September 2011, 06:19 AM   #761
jzagaja is offline jzagaja  Poland
I haven't measured yet.
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 18th September 2011, 02:08 PM   #762
K-horn (spherical profile, Klang Film KL51) directivity.
Old 18th September 2011, 04:18 PM   #763
Typical "Chinese" screw on driver cross section view.
Old 18th September 2011, 05:25 PM   #764
Modification proposal.
Old 19th September 2011, 05:29 AM   #765
Pallas is offline Pallas  Pakistan
Interesting. That looks a bit like the "tulip" waveguide in Tannoy's modern Dual Concentrics.
Old 24th September 2011, 09:05 PM   #766
Phase plug change is easy but it will destroy magnetic circuit.
Old 24th September 2011, 10:49 PM   #767
gedlee is offline gedlee  United States
gedlee's Avatar
Make the outer ring of your modified phase plug part of the magnetic circuit and it will be fine. Its no more difficult to cut or form a curve on that survface than a straight line.
You need to plot the normal flux along the gap for both designs. Its only the normal flux that contributes to the axial force. The tangential flux drives ring modes. This is very easy to do in that software.
Earl Geddes Gedlee Website
Old 25th September 2011, 07:22 PM   #768
I wanted turn myself that's why kept it straight :-) Normal flux is surprisingly quite similar in straight version (0.2T). Curved below.
Old 26th September 2011, 10:53 AM   #769
gedlee's Avatar
There is something wrong with those flux plots. They cannot be correct. Perhaps the grid is too coarse or something. You need a line placed where the VC would be, running along the voice coil, that extends past the voice coil on both ends. There should be at least ten elements along this line. The flux should fall almost to zero at each end of the plot. can you post the model?
The flux in the curved case looks pertty much the same as the original. You claimed that the changes messed up the magnetics which is not the case at all, if done correctly.
Does this phase plug correspond to my patent?
Old 26th September 2011, 11:23 AM   #770
Yes it does. I've created AxiDriver data for this plug.
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
