Group Buys Members group buys
Waveguides and horns
Old 10th June 2011, 09:20 PM   #581
agent.5 is offline agent.5  United States
Thanks Scaper for weighting them. Are the two horns stacked on top of each other to save space?
Old 10th June 2011, 09:24 PM   #582
Scaper is offline Scaper  United States
No, they're pretty much stacked side by side, back to back, with their throats next to each other.
Here's a photo that sort of shows what I mean:
A.K.A: Erich H.
Old 10th June 2011, 09:26 PM   #583
Thanks for the pic.
Old 11th June 2011, 07:44 AM   #584
jzagaja is offline jzagaja  Poland
JMLC-200 weigh between 15-20kg each depending on finish (solid surface is 20kg).
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 11th June 2011, 08:25 PM   #585
rajacat is offline rajacat  United States
Have any of the 18" SEOS's been built yet? A sonogram would be interesting to determine if bigger is always better or if there's a point of diminishing returns as far as controlled directivity is concerned.
Old 11th June 2011, 08:27 PM   #586
Yes it has and will be tested next weekend.
Old 12th June 2011, 01:37 PM   #587
A local guy tested the 15" yesterday and he was impressed. So it looks like the SEOS has been successful. The guys at AVS did a good job working together to get the design figured out. And Jzagaja and Autotech's work on the prototype looks great too.
A.K.A: Erich H.
Old 12th June 2011, 01:55 PM   #588
doug20 is offline doug20  United States
EricH, do you have any measurements? What CD was used?
Thanks!!
Old 12th June 2011, 02:14 PM   #589
Thanks!!
DE250 was used and he said it can easily be crossed at 900hz to a 15". Horizontal and vertical's measured great.
Doug, I shipped all 3 of your Iwatas a few days ago. If you don't have them right now, you will on Monday! I believe shipping was a little less than quoted, so that's good. Hoping you'll be impressed with my packaging!
Guys, keep in mind that the second group buy is underway. In a few days, I will post a list of current orders and more info on the website. If you want something, don't hesitate this time around.
A.K.A: Erich H.
Old 13th June 2011, 02:42 AM   #590
The ones I have are about 42lbs each counting how they wrapped them at Autotech. A pallet will weight about 30-50lbs on it's own depending on how it's built.
Figure my packaging will add at least 25lbs to that.
A.K.A: Erich H.
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
