Group Buys Members group buys
Waveguides and horns
Old 28th May 2011, 08:44 AM   #541
jzagaja is offline jzagaja  Poland
Full size bass horn in a room 1/3 oct. smoothing- lack of room modes.
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 28th May 2011, 11:37 AM   #542
Defo is offline Defo  Norway
Originally Posted by gedlee View Post
What is the use of "Horn gain"? I mean who cares? Can't you get high powered amps or high efficiency woofers in Europe? Directivity control is all that matters and you never show that.
Less cone movement, less power needed for a given sound pressure, less distortion, the ability to use low powered amps which very often sound better then its high powered brethren... Enough for me to care...
Old 28th May 2011, 11:41 AM   #543
Usually with OS/SEOS one use small capacitor as L-pad and CD correction (flattening power response). Resulting sensitivity drops below 100dB. Bass horn loading is then obsolete ;-)
Old 28th May 2011, 12:02 PM   #544
Not quite, you still maintain the reduction in cone movement and therefore reduction in distortion as well as increased dynamic headroom. Correct me if I'm wrong tho.
Old 28th May 2011, 01:26 PM   #545
dnewma04 is offline dnewma04  United States
So, in a small room (less than 16-20m dimensionally), what benefit can be had by using horn subwoofers? If the wavelengths are longer than room dimensions, AFAIK, it's not going to be acting like a horn (with reduced cone movement and reduced distortion), it's going to act just like a direct radiator. If I lived in an auditorium, I'd be all over using multiple horn subs.
Old 28th May 2011, 05:44 PM   #546
RockLeeEV is offline RockLeeEV  Canada
ER...
A horn subwoofer will still have the behaviour necessary for "horn loading" at down to its corner. (Motor-based) Distortion and cone movement are still reduced.
Old 29th May 2011, 02:40 AM   #547
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by RockLeeEV View Post
ER...
As does a bigger driver, and in terms of total size, its still smaller than a bass horn. Sorry to be so blunt, but bass horns in small rooms simply make no sense. That is the reality.
Earl Geddes Gedlee Website
Old 29th May 2011, 11:15 AM   #548
doug20 is offline doug20  United States
Define a small room? having clean dynamics is imporant. Having less harmonic distortion is important. Having CLEAN 120 dB with 100Watts is important to some people too. Doing it all for around $100 is well....priceless!!!!
Have you seen the low cost flat pack horns on AVSForums?? Have you seen the new F-20 horn design with 20Hz and HUGE output with a $70 driver (MFW-15). It makes a lot of sense if you look at the numbers plus the $$$.
The numbers simply say it makes a lot of sense!! here is a thread that makes a lot of sense http://www.avsforum.com/avs-vb/showthread.php?t=1329971, there is are many other builds that make sense. The DTS-10 is a monster choice for low power high output down to 12Hz.
FWIW, I choose the best subwoofer drivers instead and go sealed because I want 10Hz output (> 110dB) but my solutions is 10x more expensive. The value/performance of bass horns is not lost on me.
Old 29th May 2011, 11:45 AM   #549
You can add this 6.5" anarchy tapped horn (flat pack option) to the list of great bass horns.
Group Buy for 6.5" Anarchy Tapped Horn. - AVS Forum
HORNS do offer a GREAT VALUE!!
Old 30th May 2011, 08:00 PM   #550
Less than 50' or so in any given dimension, I'd guess.
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
