| Group Buys Members group buys |
#521 |
If I end up just using a regular 2" CD on the IWATA-300 what is a good solution for adding a horn for >= 8KHz It seems like its going to be pretty hard to a nice seemless design.
#522 |
Try small ribbons 8-60kHz (ca. 100$):
http://ans.sklep.pl/images/VENUS2%20600zw.jpg they produce a lot of "air" (a bit too much for my taste) in comparison to OSWG+4524.
Visit us at http://www.horns.pl/ The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here |
#523 | |
https://www.madisound.com/store/inde...ath=45_229_236 102db/2.83v/1m ain't bad: https://www.madisound.com/store/prod...oducts_id=1557 I just started goofing with RAAL ribbons crossing over at ~9Khz, 3rd order (= 4th with transformer), and I think the dispersion works with waveguides. YMMV. EDIT: I submitted this before seeing jzagaja's response. Kinda redundant now, but kinda not... |
#524 |
Don't never, ever blend horns with direct radiators without loading! Unless in the low region.
I have heard so many midrange horns with ribbons that just preach "look, I'm trying all I can to keep up". If you have the doe, try a couple of Fostex https://www.madisound.com/store/prod...roducts_id=293 Maybe ruin your bank-account - but they are way better than the TAD 7's and blend in much, much better. And any old JBL or whatever ring- og slit-radiator will give the "air" that's needed! Last edited by PeterDupont; 17th May 2011 at 09:53 PM. |
#525 |
First group buy is now finalized:
AVS Forum - View Single Post - Hey guys...we need a little rallying here...
#526 |
Guys, I got the pallet in from Poland and everything looks great. It's all been unpacked and I'll start wrapping the items up this weekend for shipping.
Waveguide and Horn Delivery (Photos) - AVS Forum
A.K.A: Erich H. |
#527 |
Found first pictures from Munich:
Images du High End 2011 de Munich (partie 1) http://lh6.ggpht.com/_4eOIBwikWQE/Td...I/P1090180.JPG Today's morning all play... sine sweep
#528 | |
![]() I do wish I ordered gloss black now, I will try to paint them ![]() I have the BMS 4590 on order now so I hope its a good match to the IWATA-300. Thanks Eric and Jack for all the work so far. This is going to be exciting, my horn/CD alone is more expensive them my last 3 pairs of speakers. Im trying to tone down my expectations. |
#529 |
#530 |
For wide bandwidth single horn application Iwata and Ejmlc (check website for new models) are recommended because for example JMLC-200 power response expose midrange and in weakly furnished room for some can sound like a megaphone.
Yesterday I was examining Harwood AMT 30 and Seas RNX in small 20 litres box. Very good tweeter (clean CSD) but directivity suffers and has less vivid tonality, power than let say 4524 in OS. I can describe it as typical dry, smooth sound - better than typical ribbon with exaggerated highs.
Visit us at http://www.horns.pl/ The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here Last edited by jzagaja; 24th May 2011 at 08:00 PM. |
| smith horns and using compression horns for a Karlson party speaker project | bikehorn | Multi-Way | 14 | 30th January 2013 05:20 PM |
| Horns inside of horns open foe discussion | oilcanracer | Multi-Way | 3 | 15th February 2010 03:42 AM |
| Compression drivers in horns or waveguides | 454Casull | Multi-Way | 6 | 1st December 2008 12:41 PM |
| Phase plug necessity in horns/waveguides | 454Casull | Multi-Way | 3 | 18th September 2005 07:36 PM |
| Horns: Vibrations and resonances in metal horns | Rocky | Multi-Way | 10 | 28th July 2004 01:38 AM |
