Waveguides and horns - Page 52 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 29th April 2011, 12:25 AM   #511
Gluca is offline Gluca  Italy
Gluca's Avatar
Originally Posted by doug20 View Post
I just picked up the TAD TD-2001 1" CD.
How do I use it with the Iwata-300 when the throat of the IWata is 2"??
JBL 2327 ... 2" to 1" adapter often seen on ebay.
Old 29th April 2011, 01:48 PM   #512
doug20 is offline doug20  United States
Thanks for the responses.
How does the differing angles from these adapters effect the response?
Old 30th April 2011, 11:42 AM   #513
The TAD 4001 and 2001 are Alnico-based drivers with a rather long, radial throath like the JBL 375. Due to the fact, that with Alnico - more length more flux.
The 2" - 1" adapter prolongs the hornstart with exactly the same flare.
Newer Neo-drivers are build to shorter horntypes and have a much shorter and much more angled throaths. I use the original Iwata with a 950, which has a 10 degree angle - but it is just about 10 mm. in length. With no sonically problems.
(Measurable, I don't know).
Old 5th May 2011, 09:03 PM   #514
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
Wavelets:
1) Radian 950PB+Truextent (beryllium), JMLC-350
2) BMS 4590, JMLC-200T
3) STX D1500Ti, JMLC-350
4) BMS 4538, E-JMLC-1000.
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 6th May 2011, 01:38 PM   #515
Thanks, So which is better the Radian or the BMS4590???
Im about to buy the 4590 too.
Old 6th May 2011, 01:51 PM   #516
No personal experience with Radian and Truextent. Those who had both say little difference and BMS is much cheaper.
Old 6th May 2011, 02:01 PM   #517
I was asking more about the wavelets and which one you deem to be a little better. There seems to be more ghosting at 5s for the 5490. Does that even matter???
Old 6th May 2011, 03:02 PM   #518
Early reflexion in Radian+Truextent hides ghosting so we can't say for sure which is better. If I remember correctly TAD wavelets presented by Jean-Michel were cleaner. Take into account Radian with Truextent is 3x more expensive.
Old 6th May 2011, 04:27 PM   #519
Paul W is offline Paul W  United States
Paul W's Avatar
Do you have measurements of the Radian with the standard aluminum dome?
Paul
Old 7th May 2011, 12:14 PM   #520
Measurements were kindly provided by Behringer Electric and I think they have alu dome too. Enclosed maroon colored solid surface JMLC-200T.
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
Copyright ©1999-2017 diyAudio
