Group Buys Members group buys
Waveguides and horns
Old 24th March 2011, 04:29 PM   #431
jzagaja is offline jzagaja  Poland
You can CNC adapter locally - spreadsheets are available.
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 24th March 2011, 04:33 PM   #432
Paul W is offline Paul W  United States
Paul W's Avatar
Jack,
What measurement distance do you use? Distance to throat or mouth?
Paul
Old 24th March 2011, 04:33 PM   #433
Hottest projects in summer 2011: OB and WG for dipole RAAL 140-15d.
Old 24th March 2011, 04:36 PM   #434
Originally Posted by Paul W View Post
Jack,
From mouth 80-100cm (30-40 inches) when in room, BK4149 with 2610 amp.
Old 24th March 2011, 05:10 PM   #435
badman is offline badman  United States
badman's Avatar
I don't see the value in using the same size horn for the tweeter.....
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 24th March 2011, 07:09 PM   #436
JoshK is offline JoshK  Canada
Originally Posted by krzys View Post
Do I interpret it right? The Tractrix is the smoothest, the Miniphase is the less directional although not so smooth and the JMLC is very directional (beams)?
Chris
No I don't think that is right. Compare the -5db contours for both the tractrix and the JMLC and you will see that the tractrix has a much narrower beamwidth at higher freq than the JMLC, which is to say the tractrix beams more. Its rate of change of beamwidth is a little slower however, but its coverage is narrower.
Old 24th March 2011, 07:30 PM   #437
krzys is offline krzys  Canada
To joshK, this time I looked carefully. Both have about the same coverage up to 10 kHz then JMLC narrows quicker.
I then have another question: what does it mean that the JMLC has strong 2.5 dB contour and Tractrix don’t have it at all? different efficiency of the horns? JMLC would play louder on axis ?
Chris
Old 27th March 2011, 01:46 PM   #438
Tractrix beams less - see attached half polar. New waveguide concept for RAAL 140-15d.
Old 28th March 2011, 01:11 PM   #439
Jmmlc is offline Jmmlc  France
R.I.P.
Hello Jack
Correct and Tractrix is almost two times smaller.
About the way to analyse the directivity maps you obtained from your measurements, my own views will differ somewhat of yours.
I took your maps for both the 200Hz Tractrix and the 200Hz Le Cléac'h horn and removed the frequency above 4500Hz as the response in that range is due to the tweeter part of the coaxial BMS driver which one possess a diameter much smaller than the throat diameter of the horn.
Between 450Hz and 4000Hz I draw two straight lines (white color) passing through the -5dB limits of the polar map of the Le CLéac'h horn and reproduce the same 2 lines on the polar map of the tractrix.
Your polar map for the 200Hz Le Cléac'h horn is consistent with the FEA simulation performed by John Sheerin which one indicate a very smooth variation of the directivity with the frequency (very few refelctions and HOMs inside the horn).
http://ldsg.snippets.org/HORNS/image..._flat_wave.jpg
As we can see on the attached graph is that the directivity of the 200Hz Le Cleac'h is equal or smaller than the one of the Tractrix from 450Hz to 4000Hz.
From 400Hz to 1800Hz the -5dB line fro the the tractrix deviate from the white reference lines and I enlightened the zone comprised between the -5dB line and the white lines. On that frequency interval the directivity is more larger for the Tractrix (more beaming in that frequency range). I intrepret that zone as the result of backreflected, reflected or diffracted waves interfering with the direct wave. This should be probably attenuated if the tractrix horn was included at its mouth to a large planar baffle.
You polar map for the 200Hz tractrix is less consistent with John Sheerin's simulation of a tractrix horn. Most probably the reason is because in John Sheerin's simulation the tractrix horn is inserted in an infinite baffle.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Old 28th March 2011, 08:52 PM   #440
Depends on frequency window and normalization.
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 06:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 04:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 01:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 08:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 02:38 AM
