Waveguides and horns - Page 142 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 10th May 2013, 11:48 PM   #1411
hi jzagaja, could you please tell me about the 2" iwata-300 with 1.4" optional reduction? Is the reduction a separate add on piece for the 2" horn? I have'nt decided which driver to use, but if I ordered the 2" iwata with optional reduction, I was hoping I could experiment with both voice coil sizes. Thanks.
-Nate
Old 11th May 2013, 06:40 PM   #1412
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
Knowing compression driver throat angle order locally or from Autotech optional conical adapter.
Below chrome plated mounting of TH4001 clone. More pictures to come...
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 12th May 2013, 11:43 AM   #1413
Biradial 2".
Old 12th May 2013, 07:10 PM   #1414
In front of stereo setup.
Old 13th May 2013, 12:09 AM   #1415
Face is offline Face  United States
Face's Avatar
Jzagaja, do you happen to know the exit angle of Faital Pro comp drivers, specifically for their 1.4" drivers? I'm trying to find out if they're compatible with SEOS waveguides.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 13th May 2013, 05:32 AM   #1416
Sorry I don't know
Old 19th May 2013, 05:16 PM   #1417
Hello everyone,
These SEOS looks impressive, I hope it sounds great too !
I would like to know if the SEOS 12 is/would be available in solid surface (resin) ?
The SEOS 15 seems to be the only horn in the SEOS range to be available in this form but I don't need to cross much lower so the SEOS 12 is perfect for me and the directivity seems a "bit" more wider/better controled than the SEOS 15.
Thanks in advance for your answers and returns of experinces,
Stephane.
Old 19th May 2013, 06:53 PM   #1418
Both SEOS-12 and SEOS-15 are available in resin (solid surface). They are heavier and cheaper.
Old 20th May 2013, 04:46 PM   #1419
Thank you !
Is there any difference sound wise between the fiberglass version and the resin version ?
Instinctively I'll say that the resin horn is "better" because more mass=better dampening=less resonances, but with a well made and well calculated horn it should be negligible.
Old 20th May 2013, 04:49 PM   #1420
Resin is more damped - I've shown acceleometer spectra in this thread.
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
Copyright ©1999-2017 diyAudio
