Group Buys Members group buys
Waveguides and horns
Old 12th January 2013, 05:39 PM   #1291
Tytte71 is offline Tytte71  Norway
I'm selfish and want SEOS18 1.4" with 0deg Also have 1.5" driver that is optimized for 0deg throat.
Old 12th January 2013, 05:41 PM   #1292
jzagaja is offline jzagaja  Poland
Radian 951? I'll check angles at 1.5".
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 12th January 2013, 07:11 PM   #1293
Yupp, Be edition At the moment it is playing in a mock-up with E-OS15... Really nice WG and driver - I can recommend this combo!
Old 12th January 2013, 09:31 PM   #1294
Measuring with BK2012 is very fast - faster than ARTA. Just two buttons when delay is set. When done save as ASCII (by using autosequence). Polars are stored in 36 curves as Z-Axis. Excel 2007 must be used because older does not accept more than 256 columns
Below is resulting data for those who willing to try make a crossover: Mummy equipped with BC DE500 and 12B100R. Angles: 0,5,10,15,20,30,40,50,60,80,100,120,150,180.
Old 12th January 2013, 11:16 PM   #1295
Spreadsheet for sound power calculation of above data.
Old 13th January 2013, 12:17 AM   #1296
NiToNi is offline NiToNi  United Kingdom
Banned
Originally Posted by jzagaja View Post
No with 7deg (14deg full) Should I set to 0 deg? Then it is difficult adopt both 1.4 and 1.5 inchers )
Yes, I am almost certain that the throat angle is almost zero degrees on the 951Pb but it would be great if someone could confirm the exact number. I think also the inner diameter is marginally greater that the outer.
This is great! So when can we order?
Old 13th January 2013, 12:30 PM   #1297
I don't have it confirmed by Radian or having a sectional drawing of the driver, but I tried to measure it without dismantling the bug screen. According to Guido Behringer the phase plug exit is Ř1.5". I measured 17mm from the exit to the phase plug. This implies a negative half angle of some 4deg.
Old 13th January 2013, 07:54 PM   #1298
Negative angle is worst thing because demoulding requires positive angle.
Old 14th January 2013, 09:08 AM   #1299
Please don't blame me 0deg should be close enough?
Old 14th January 2013, 09:10 AM   #1300
Of course - we will make as close as 0deg as possible
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 06:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 04:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 01:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 08:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 02:38 AM
Copyright ©1999-2017 diyAudio
