| Group Buys Members group buys |
#1251 |
Fatbattery - isn't it Tractrix: 110, 200, 350, 600, 1000 what you look for?
Visit us at http://www.horns.pl/ The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here |
#1252 |
I just wanted to let everyone know that I are working on group buy #4 for the Autotech horns and waveguides.
The pallet should fill up pretty quick, so if there's something you want, please let me know as soon as possible.
A.K.A: Erich H. |
#1253 |
#1254 |
No more than 6dB.
#1255 |
Here is example of impedance autosequence followed by show parameters sequence. Some noise below 10Hz is visible. Can be grounding problem or back emf - resistor instead of speaker measures similarly.
#1256 |
BMS 4590 impedance around resonance with calculated parameters.
#1257 | |
Google Translate |
#1258 |
If you have some dimensions let me know.
#1259 |
#1260 |
Regarding aquaplas- I made my own "baddyplas", using tacky glue and talc. Applied to selenium d2500ti diaphragms, (same embossed Ti as the 220Ti used for "Econowave"), it made a very nice difference to the highs- they sound fuller but less spitty. I attribute this to a likely general smoothing of the top end peaks and dips.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
| smith horns and using compression horns for a Karlson party speaker project | bikehorn | Multi-Way | 14 | 30th January 2013 05:20 PM |
| Horns inside of horns open foe discussion | oilcanracer | Multi-Way | 3 | 15th February 2010 03:42 AM |
| Compression drivers in horns or waveguides | 454Casull | Multi-Way | 6 | 1st December 2008 12:41 PM |
| Phase plug necessity in horns/waveguides | 454Casull | Multi-Way | 3 | 18th September 2005 07:36 PM |
| Horns: Vibrations and resonances in metal horns | Rocky | Multi-Way | 10 | 28th July 2004 01:38 AM |
