Group Buys Members group buys
Waveguides and horns
Old 20th November 2012, 01:48 PM   #1231
anubisgrau is offline anubisgrau  Serbia
Originally Posted by hum4god View Post
Hi jzagaja
did you ever get a chance to listen and measure the B&C DCM50 with one of your horns?
i would be especially interested how it sounds and measures w/ the Iwata 300 ?
thanks
Originally Posted by jzagaja View Post
Not yet. We use BMS and Radian/Truextent.
jzagaja, was there any development re B&C DCM50 and your horns?
if you haven't had a chance, what would you recommend as the best horn from your production to extend a lower end as much as possible (recommended by B&C is 400hz but i would love at least 350hz with few watts...) while having clean dispersion without beaming or other nasty artefacts.
also i can't find more comments on your minphase 200 horn, the price is much more affordable than JMLC and it looks like it has a very similar lip-over. how does it behave in the mids?
are there any plans for really big OSWG, like 18" or similar? since i've heard geddes OSWG (from summa), i think it's a way to go in smaller rooms....
Old 20th November 2012, 03:43 PM   #1232
jzagaja is offline jzagaja  Poland
B&C DCM50 is uknown for me. JMLC-200 is too beamy for your needs. Minphase with BMS 4590 is 400Hz (-6dB) and optically large, Biradial still untested.
Large SEOS/EOS - still waiting for group buy (end of this year?).
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 20th November 2012, 03:49 PM   #1233
thank you, re beaming mind that the desired range for DCM50 in my application is 350-1.5 (even less)....
Old 20th November 2012, 03:55 PM   #1234
Now it's simple - Tractrix200.
Old 20th November 2012, 07:50 PM   #1235
Today I've learned how to store graphs in BK2012. This is quite easy - you have to chose plotter as output device, then open in ABViewer for example and format. Quick and dirty comparison between 12BR70+D800Ti vs. 12B100R+DE500. Level was quite low a bit below 1Vrms but I couldn't set more because of family members. I'm sending Mummy 4 (12BR70+D800Ti) with minimalistic crossover to Lukasz for voicing, attaching Aquaplased diaphragms.
Pink is 12B100R
Old 21st November 2012, 06:50 PM   #1236
Second Aquaplased sample - one I've sent to Lukasz so couldn't compare but it looks worse. Practice needed.
Old 22nd November 2012, 07:05 PM   #1237
tuyen is offline tuyen  Australia
Send a message via MSN to tuyen
For a tweeter (bms 4540nd 1") that is to play >2000hz, would the choice of the iwata 600, e-jmlc 600 or 1000 be the best choice?
I'd be interested in a pair..
Cheers
Old 22nd November 2012, 07:09 PM   #1238
Yes any 600Hz horn or SEOS-15 waveguide is a good choice depends on your taste.
Old 22nd November 2012, 07:57 PM   #1239
For comparison Harwood AM35 direct radiator with 6" woofer.
Old 24th November 2012, 03:46 PM   #1240
Mummy 3 (12B100R+DE500) measured in BK 2012 analyzer with and without reference resistor versus LIMP with reference resistor 18Ohm. Obsereve change in tuning frequency and Q of resonance peaks.
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
