Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 29th October 2012, 11:30 AM   #1221
Tytte71 is offline Tytte71  Norway
Looks like a nice improvement with the Aquaplas, needing less correction and better time domain performance (wonder if distortion figures improves as well). Have you done any listening comparison?
Also, how much Aquaplas did you add?
Old 29th October 2012, 07:08 PM   #1222
Originally Posted by gedlee View Post
It was 6 or 6.5° (I don't remember the decimal places) - half angle.
6.5 degrees half angle would make it 13 degrees included angle as I mentioned.
Old 29th October 2012, 10:03 PM   #1223
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
Will send sample diaphragms to Autotech for evaluation. Hard to say how much Aquaplas - just to cover diaphragm completely with white coating. About 7-10 layers.
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 29th October 2012, 10:14 PM   #1224
The sensitivity takes a big hit from the extra mass of the Aquaplas.
Standard application recommendation for optimum damping of diaphragm resonances is to cover the center 25%, as that is where amplitude is greatest.
If you wanted to get fancy you could effect constrained layer damping by adhering a small disk, or maybe two crossed strips for less mass, of aluminum foil to the center of the diaphragm.
Noah
Old 14th November 2012, 06:03 PM   #1225
Applying Aquaplas using table top fan:
https://docs.google.com/open?id=0ByP...05GWmhoN2huaEE
Old 17th November 2012, 05:48 PM   #1226
First day of using Bruel Kjaer 2012 Audio Analyzer - setting up Mummy crossover (12BR70+D800Ti). I would like to contact anyone familiar with this nice machine.
Old 18th November 2012, 02:35 PM   #1227
Intermodulation distortion with and without Aquaplas.
Old 18th November 2012, 05:32 PM   #1228
Interesting isn't it? Both ends are nicely lowered but waveguide modes region is not. I need to change base frequency and check again - maybe I hit a HOM
Old 19th November 2012, 07:15 PM   #1229
D800Ti when equalized (2 notches) has dip at 2.6kHz - Aquaplas may help.
Old 19th November 2012, 08:08 PM   #1230
Problem with stiff suspension drivers like D800Ti is crossover point below 1kHz. Higher is problematic due to driver/waveguide resonance. Don't be afraid of 12BR70 higher midrange distortion - it's not a problem as seen on below picture.
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
Copyright ©1999-2013 diyAudio
